brakes stopped working?
Old Jun 27, 2009 | 08:25 PM
miky2001's Avatar
miky2001
Default brakes stopped working?
i was driving home today after a nice long drive and a deer shot out in front of me.
i had to slam on the brakes and i missed it by inches.
the brakes did their job.
however, the next time i stepped on the pedal the brakes hardly worked at all, so i drove the 2 more blocks home.
my brakes hardly stop the car now even tho i have good pressure at the pedal.
i looked at the master cylinder, wheels, junction block and i see no signs of a leak.
any ideas what my problem is, or how i can fix it?
thanks a lot
mike
Old Jun 27, 2009 | 08:38 PM
Peterbuilt's Avatar
Peterbuilt
Try bleeding the brakes and see if that helps. If you get air out of the calipers in the back it could be a run out problem. If your pedal goes back to normal be careful of the next few rides because if it is a run out problem the brakes will fail again after so many miles. PG.
Old Jun 27, 2009 | 08:40 PM
wnmech's Avatar
wnmech
Is your pedal pressure real hard? You may of blown out the diaphram on your power brake booster. There is also a filter in the line that goes between the booster and the connection on your manifold that will fail. If thats alright I would check the proportioning valve mounted down on your frame.
To brakes stopped working?
