Flex Plate Question
Old Jun 29, 2009 | 08:41 PM
willem wallace's Avatar
willem wallace
Default Flex Plate Question
Have a GMPP ZZ383 and getting ready to bolt up transmission(Turbo 400) and drop into frame. Happen to be looking at the GMPP flexplate
12.75"X152 tooth. Has 3 raised ears spaced evenly around the plate that I am assuming I am bolting the torque converter to. My question is two of the holes are exactly same 1/2" but the third hole is way smaller and oblong shaped, maybe 3/16" with a tiny hole above it. What am I missing here? Does the converter bolt to a different set of holes on the flexplate? Rookie here, so bear with me. Any info is appreciated.
Old Jun 30, 2009 | 09:37 AM
jackson's Avatar
jackson
Suggest you first verify diameter of the bolt circle on YOUR TH400 convertor ... then verify YOUR 153T flexplate has same diameter bolt circle.
I suspect you will need another flexplate or convertor. Unless you have mini-starter, straight-pattern etc requiring a small 153T flexplate, I suggest you use the larger 168T flexplate.
Old Jun 30, 2009 | 01:20 PM
Buzzardz_vette's Avatar
Buzzardz_vette
Originally Posted by jackson
..., I suggest you use the larger 168T flexplate.
Why? I have a mini starter that can use either a 153T or 168T flexplate (you just mount it differently, staggered vs straight bolts). I had a 153T one so I went with that setup. Is there an advantage to using the 168T?
Old Jun 30, 2009 | 10:28 PM
jackson's Avatar
jackson
Why? ... Not all mini's are adaptable/clockable & staggered/straight 153T or 168T ... maybe yours is but others are not. Neither do all blocks have two pair of straight holes. I dunno which starter WW has. Also, I dunno, but have a sneaking suspicion WW's small GMPP flexplate may not have the large bolt circle to match his TH400 convertor.
Old Jul 1, 2009 | 08:58 AM
Buzzardz_vette
So, all else being equal, there should be no noticeable difference between the two? I'm was just curious as to whether or not I should switch to the 168T being as my starter can use either one. Since it doesn't seem to matter, and I have already reinstalled the engine and trans, I'll just leave the 153T flexplate in it. Thanks.
Old Jul 1, 2009 | 09:50 AM
willem wallace
Default Torque Converter
Torque converters for both the t-350 and t-400 come in two different bolt patterns, 10.75" and 11.50". My 12.75" 153 tooth flexplate, takes the 10.75" converter. None of this has anything to do with my original question.
Old Jul 1, 2009 | 11:34 AM
jackson's Avatar
jackson
Your original issue is moot if your convertor has typical larger 11.5 bc. Do you know YOUR 400 convertor has the smaller 10.75 bc ? Perhaps it does but you haven't said. Was simply trying to (potentially) save you a step or two. Never mind & good luck.
To Flex Plate Question
