I have VBP Performance Plus with VBP Offset Trailing Arms, Dual Mount Rear Spring, and rear swaybar. My question is, what size wheels/tires can I go with on the front/rear and what size spacers do I need for the front/rear with keeping the rear swaybar? Thanks!
You should be ok with 2.5" adapteres in the front, and 2.75" adapters in the rear. You could use 2.5" adapters in the rear if you modify your sway bar, like I did.
Bee Jay
Bee Jay
Should I stick with 17x9.5 front and rear or go with 18's on the rear? I'll be pushing close to 500 HP, so would it be better to lose the swaybar to add some extra meat in the back?
Disconnect your sway bar and drive the car. See how it feels. I did and didn't like the sway bar less feel. So I modified the sway bar to fit my 18x9.5" wheels. Further mods were needed when I moved up to 18x10.5" wheels. I'd go with 18s in the back to get the 26" rolling diameter with 40 series tires. But if I was getting C6 Z06 wheels, I'd go with the stock 19" wheels in the back.
Bee Jay
