Silicone Brake Fluid
I think what's much more important than your choice of fluid is simply keeping the fluid clean and the entire brake system in good working order.
not to use the springs behind caliper pistons...not needed with Oring pistons.....
check runout so as on the rear, engine running on stands under the T-arms...you can feel the pads against the rotors.....and see how much if any lateral runout you have, it has to be nearly zero....1/32 at most....but with Orings, that's fine....
AFTER that, you know the brake hydraulics are fine....and IF you not happy with the 'feel' of the pedal.....
we get into more modifications.....
another thread....
Gary
same here, alcohol flush and blow dry. Let the silicone sit on the shelf for several days in the warm garage or in the sun, that will get rid of the bubbles in the jug. Don't chake it like a can of tomato juice. 1 quart will be plenty, but get 2. Sometimes its hard to get all the air out of the system. Push the pistons all the way in the calipers and gravity bleed the system+
http://www.jegs.com/p/Wilwood/Wilwoo...53141/10002/-1
On my street cars without ABS, I do use Silicone and have for many years without any problems. I even used it on my '73 that I autocrossed for a number of years with no problems. VB&P sells an excellent Silicone brake fluid at a very competitive price. One quart should be all you need.
Good luck with your decision... GUSTO
The silicone has a higher boiling point than DOT 3 & 4 and should be suitable even in racing applications. Don't confuse silicone DOT 5 with DOT 5.1 which is glycol based. Also, good point made about ABS and silicone incompatibility.
"Minimal boiling points for these specifications are as follows (wet boiling point defined as 3.7% water by volume):
Boiling point ranges
Dry boiling point Wet boiling point
DOT 3 205°C (401°F) 140°C (284°F) GLYCOL
DOT 4 230°C (446°F) 155°C (311°F) GLYCOL
DOT 5 260°C (500°F) 180°C (356°F) SILICONE
DOT 5.1 270°C (518°F) 191°C ( 376°F) GLYCOL
DOT 4, like DOT 3 and DOT 5.1, is a polyethylene glycol-based fluid (contrasted with DOT 5 which is silicone-based). Fluids such as DOT 4 are hygroscopic and will absorb water from the atmosphere. This degrades the fluid's performance, and if allowed to accumulate over a period of time, can drastically reduce its boiling point. In a passenger car this is not much of an issue, but can be of serious concerns in race cars or motorcycles.
As of 2006[update], most cars produced in the U.S. use DOT 3 brake fluid." <<< because of ABS and expense I presume.
I good pressure bleeder is very useful in accomplishing a good brake bleed....http://www.automedia.com/Power-Bleed...cr20050501pb/1 Summit sells them. As far as silicone fluid... I find it easy to acquire at the local auto parts store such as Advance Auto Parts
Here's a link to a post about bleeding sequence FWIW
http://forums.corvetteforum.com/c3-t...ing-order.html
1. Silicone is compressible; meaning pedal feel will be effected in what some consider a bad way. Certainly not what the enthusiast track user would consider ideal.
2. Silicone may be harder to source should you find yourself in need of some at an odd location and time.
3. Once in the system it will be very difficult to purge it from the system fully and replace with conventional fluid. Even small amounts of it can become compressed and will act as bubbles in the regular fluid.
Ideal for show cars where potential paint damage and a long life with little or no attention is the goal...but for most street applications I'd probably not go this way.
1. Silicone is compressible; meaning pedal feel will be effected in what some consider a bad way. Certainly not what the enthusiast track user would consider ideal.2. Silicone may be harder to source should you find yourself in need of some at an odd location and time.
100% OTM
