Installing door handle
Old Jul 2, 2009 | 08:23 PM
Lorin D's Avatar
Lorin D
Default Installing door handle
Is there a little trick or something on installing door handle to the
inside door opening control ? I had to replace the inside door opening
control on the left side . Tried it with door panel on first. Then with the
panel off tried sliding the panel over the attached door handle It got me talking to myself a lot more than I normally do- I might add . I would appreciate any help or ideas . I replaced the right side with very little problems . Thanks in advance . . .
Old Jul 2, 2009 | 09:23 PM
...Roger...'s Avatar
...Roger...
If you try to slide the handle in place with the door panel on you run the risk of breaking the slots in the new door opening control. I install the handle and then the door panel,I have a loop I put around the handle to pull it out far enough to slide the door panel over it.
Old Jul 2, 2009 | 10:08 PM
7T1vette's Avatar
7T1vette
That will do it. Or, if you have long, thin arms, you can reach in from the front end of the panel and use fingers [behind the lever] to push the end of the handle through the inner panel. {I like the "loop" idea above.}
To Installing door handle
