Help needed with a grumpy old lady!!!
Old Jul 2, 2009 | 09:33 PM
black15belt's Avatar
black15belt
Default Help needed with a grumpy old lady!!!
although we have started her up 5-10 times and taken her to around 4500 rpm's, she continues to backfire, flame randomly out of the carburator, and overall very grumpy!!! we have tried some carb and choke cleaner although it has not done much, although we have some fuel additive stuff to "clean out the carburator" that will go in after the next 5 gallons of gas we give 'er. should we wait and see what it does? or should we try something more potent? like the starting spray stuff?? any tips?
Old Jul 2, 2009 | 09:54 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
I think to get a good reply you may have to post a few more details like what engine and carb; stock or modified; what has been done so far. Sounds like a timing issue though if you're getting flames from the carb. ??
Old Jul 2, 2009 | 10:00 PM
Mad Vette's Avatar
Mad Vette
More information needed like what year? What engine? Has it been modified before or stock? What work has been done?
Old Jul 2, 2009 | 10:05 PM
7T1vette's Avatar
7T1vette
Sounds like the timing is off (regardless of what the damper mark indicates) and/or the cam timing is off [timing chain marks not aligned].
Old Jul 2, 2009 | 10:10 PM
petronix's Avatar
petronix
Fouled plugs, bad wires?
Old Jul 3, 2009 | 12:39 AM
billla's Avatar
billla
St. Jude Donor '14
Timing...or incorrect cam installation :/
Old Jul 3, 2009 | 03:55 AM
73StreetRace's Avatar
73StreetRace
You said "old lady", hmmm. Generally, I don't use carb cleaner on a brand new carb, so maybe old carb too
Check fuel level in the fuel bowls,
Check fuel pressure ( 4 - 7 PSI ),
Look for clogged fuel filters,
Remove air cleaner and check squirters,
Check timing,
Check spark plugs color ( wet, fouled, bone white )
If the car didn't run for a long time, you could have old fuel deposits ( kind of varnish ) inside the carb.
Carb cleaner in the venturies WILL NOT REMOVE them.
AND a picture and some specs could help to diagnose
Old Jul 3, 2009 | 12:09 PM
wytevette's Avatar
wytevette
Plug wires going to the wrong cylinder(s)? That is, if you put new wires on or monkeyed with them?
Old Jul 3, 2009 | 12:40 PM
Red70vette's Avatar
Red70vette
All the junk you are pouring down the carb will not slove the problem. Sometimes that stuff will help minimally but it will not solve a problem like yours.
You need to post more details. Engine, carb, new, rebuilt, sitting a while, first time running, what has been done to engine, stock or modified????
The more you tell the more help you can get. Previous suggestions are a good place to start - timing, or plug wire routing but tell us how you got to this point..
Old Jul 3, 2009 | 12:43 PM
midyearvette's Avatar
midyearvette
crossed wires??
Old Jul 3, 2009 | 01:31 PM
71406's Avatar
71406
Your profile says you have a 71. If it has points, put a new set in and adjust to specs. Then set the timing. From this point on it will be easier to diagnose. If you have points and they are worn or out of adjustment you will never get it to run properly.
Old Jul 5, 2009 | 12:50 AM
paks71's Avatar
paks71
Cruising
Background on the Corvette in question:
1971 coupe base engine, auto, air, engine rebuilt in 1985, about 3000 miles on the engine since rebuild. Everything stock, everything mechanical in great working condition the last time she was driven 18 years ago. Garage stored all these years. Last month replaced fuel tank, rubber fuel lines, fuel pump, external and internal fuel filters, changed oil + filter, coolant, new spark plugs. Old points, a little film of rust on them but cleaned up fine with a few strokes of emery board. Stock Qjet. Engine running roughly but will not idle in park or drive. Car still not drivable (no brakes, haven't checked out steering, suspension, or transmission yet, needs tires).
It's worth rechecking we got the right plug wires back on the right spark plugs after we changed the plugs. Have not adjusted timing so wouldn't expect it to be off just from sitting. I figure a good Qjet rebuild would help a lot but would rather not do that unless really necessary since I've only done it once some 20+ years ago.
Thanks for your help!
-pak
To Help needed with a grumpy old lady!!!
