same vacuum source for pcv/lamps/booster?
Old Jul 4, 2009 | 01:01 PM
bowtie racing's Avatar
bowtie racing
Default same vacuum source for pcv/lamps/booster?
I have only one useable vacuum source in carb/manifold combination. Can just run one single 3/8" line and tee it for PCV,headligghts and brake booster ?
Old Jul 4, 2009 | 01:22 PM
...Roger...'s Avatar
...Roger...
Why ?
Old Jul 4, 2009 | 01:25 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Originally Posted by DWncchs
Why ?
what did you change?
Old Jul 4, 2009 | 01:50 PM
bowtie racing
Intake and carb. I dont want to tap and drill anything on to manifold and speed demon has only one large port .
Old Jul 4, 2009 | 01:56 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Racing mani with out threaded ports?
I guess it will work.
Old Jul 4, 2009 | 01:58 PM
...Roger...
Sorry I missed that you were asking if you could. I think your stretching it trying to run the pcv and booster off the same port but try it and if you don't have any hard pedal braking problems then you should be OK. The headlights shouldnt be a problem they are on or off and only use vacuum for a second or so.
To same vacuum source for pcv/lamps/booster?
