Lights wiper vacuum problem
Old Jul 5, 2009 | 02:42 PM
nutsy's Avatar
nutsy
Default Lights wiper vacuum problem
need help. went for a cruise today and as i was driving my wiper door and headlights went up on my 72 and are staying ther. anyone know what to check? thanks, nutsy. NEVER MIND. i just found a vacuum line that came off, thanks, nutsy.
Old Jul 5, 2009 | 02:55 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The problem is probably on the control side. This is the small hose part of the system.
I would check the hose at the vacuum check valve and move forward from there.
The next stop I would check is the T under the dash. This is where the vacuum hose T’s off and runs to the headlamp switch and the wiper door solenoid on the back of the tach. Since both sides are being affected I would start here.
It could be a loose/cracked hose on the headlamp switch, tach solenoid, over-ride switch, or actuator relay. Pretty much anything with a small hose hooked to it could cause this same problem (Vacuum leak).
Willcox Inc.
Old Jul 5, 2009 | 04:04 PM
nutsy's Avatar
nutsy
thanks WILLCOX. i found the problem. 1 of the hoses that go to the chrome looking peice in your diagram came off. all good now, thanks, nutsy.
Old Jul 5, 2009 | 09:12 PM
0Willcox Corvette
Former Vendor
Great! Not sure what chrome thing it is, I'll guess the hose came off the Check valve. If so, this probably made the car run a little better too! Glad you fixed it
Willcox
Old Jul 6, 2009 | 11:47 AM
Dantana's Avatar
Dantana
I wouldn't even want to start on mine since someone removed most of the system and the wipers on ly work when the button is pushed in...
great diagram though!
To Lights wiper vacuum problem
