Steering wheel play
Old Jul 8, 2009 | 12:34 AM
79VetOwner's Avatar
79VetOwner
Default Steering wheel play
What should I look into if my steering wheel has a lot of play?
I have a stock column but it ties into a VBP rack and pinion underneath.
I installed it a couple of years ago and after the alignment it was fine, now something must have vibrated loose but I cant find anything.
What should I look for?
Old Jul 8, 2009 | 05:23 PM
grandmastercorvette's Avatar
0grandmastercorvette
Former Vendor
Call VB&P and talk to their tech dept. Outer tie rod ends loose or worn out? The union where the rack meets the steering column. The actual mounting of the rack loose. The screws that secure the steering wheel to the hub.
"DUB"
Old Jul 9, 2009 | 01:32 AM
Gale Banks 80''s Avatar
Gale Banks 80'
I have the same problem. get somebody to wiggle the Wheel back and forth wile Your underneith. I'll bet that the bottom bearing in the steering Column is shot and thats allowing the U-Joints for the Steeroids to move around.
Old Jul 10, 2009 | 10:23 AM
79VetOwner's Avatar
79VetOwner
Ok Thanks. I will check out some stuff underneath and/or call vbp. I will update when I know something.
To Steering wheel play
