new ZL1 block. advises?
Old Jul 8, 2009 | 01:19 AM
elle88's Avatar
elle88
Default new ZL1 block. advises?
Ok , I can't stop an oil leak at cyl 5 on my 427 L88 type...it should be an oil ring or worn cyl wall ( the bore has a ridge at the top, bores are already at + 030.)
If I have to take the engine out, just thinking to go for a GMPP ZL1 block 12370850. the $5000 price is not too bad.
does someone have any experience on this Alu block? can I move all the parts from my engine to this block?I already have the GMPP alu heads -the 572 cid type
reliability problems?
of course if someone has one of these ZL1 blocks at better price...
and i can always resell my block to get back some $$$ : it's a 68 CE replacement block
any advise is welcome , as usual
Aldo
Old Jul 8, 2009 | 08:07 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
You could easily bore it to .060" plenty of room.
If I was looking at aluminum blocks I'd be looking to Dart etc for some real meat in them.
JIM
Old Jul 8, 2009 | 09:19 AM
elle88's Avatar
elle88
JIM
Jim
I want to reuse everything of my engine, pistons included.
so if I have to restore the block I have , I would work only on the bad cylinder bore : bore it and sleeve at + .030.
the other cylinder bores are OK and the engine has really few miles on it but something went wrong just at fifth cyl.
If I go for a an aluminum block I would stay with GMPP just because of the brand...and don't go too far away from the original L88 project where I started. I would use all the genuine L88 parts I have in my engine ( dimple rods, L88 pushrods, L88 -Zl1 cam , flat tappet, GM steel crank...)
I'm new to Dart as brand , I'll get infos...
Old Jul 8, 2009 | 01:24 PM
elle88's Avatar
elle88
more inputs please...
If I'm not wrong the forum member "lightweight..." uses just the GMPP ZL1 block in his race 68 vette...
Old Jul 8, 2009 | 04:10 PM
Alan 71's Avatar
Alan 71
Hi Aldo,
If $5000 isn't "too bad" in your world could you make me a small loan?
Regards,
Alan
Old Jul 8, 2009 | 05:33 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I would look for the real problem in cyl.#5 instead of tossing $$$$ in a new aluminum block. Maybe its as simple as replacing piston rings.
Old Jul 8, 2009 | 05:41 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Originally Posted by Alan 71
Hi Aldo,
Regards,
Alan
Too funny Alan.
Unless of course, his money is low hanging fruit on the tree, ready for pickin'?
Old Jul 8, 2009 | 08:21 PM
TimAT's Avatar
TimAT
If you can find the GMPP aluminum block. From what I've heard they sold pretty fast after the release.
Look at Dart and Brodix if you're serious about an aluminum block. Tougher stuff.
I'd find out what's going on with #5. Could be that the guy that assembled it missed the ring gaps or stacked an oil ring.
Old Jul 8, 2009 | 08:26 PM
chris75stingray's Avatar
chris75stingray
i'd check out whats wrong like everyone else said. could be a valve seal too
Old Jul 8, 2009 | 11:11 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
The ZL-1 block is readily available. Google "12370850 Aluminum Block" and you'll see dozens of vendors with varying prices; $4500 to $6000.
Old Jul 9, 2009 | 01:21 AM
Gale Banks 80''s Avatar
Gale Banks 80'
I'm useing a GM Aluminum Block although its a Small Block and not a Big Block. My engine builder said it was the Best Block He has ever used no Grinding to assemble the Engine. Most aftermarket Blocks require a test fit to see what rubs and then some Grinding and then Assemble and find something more to be gound and then the same thing all over again. My GM Block was manufactured by March Performance if I remember right. 5k is an exspensive way to save 40lbs, but there is nothing like having an all Aluminum Engine.
Old Jul 9, 2009 | 01:40 AM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Originally Posted by elle88
Jim
I don't understand. You'll drop $5k on a block but don't want to replace the internals or bore your current block? If you have ridges at the top of the block chances are you're pistons are shot too. I wouldn't sleeve that block unless there is NO other alternative. So if you're gonna buy a block, why not get one of these and build a 540?
http://www.gmpartsdirect.com/results...row=6&pkgid=67
P/N: 25534362
(boy, I'm full of good advice tonite!)
Old Jul 9, 2009 | 04:50 PM
elle88's Avatar
elle88
the idea to restore my block is not very exciting...pull it out, do the job, repaint...just to fix a broken thing. If I'll decide for it , I'll delay the thing to winter for sure.
Instead I'm so amazed by the aluminum block idea, that I would start tomorrrow...but better to take a little time
I know that with an alu block I'll loose power , but being "european" I'm more intrigued by the weight loss than power. the GMPP alu block is not the stronger ( Dart, brodix....are a bit heavier but surely stronger) but weights just 110lbs. I would save 160lbs on the front of my car. I think the car would handle as I would like.
BTW, if I decide to keep the iron block I have, what's best to do and why?
please consider that just 1 cylinder bore is tapered, the others not. the engine has few miles and bores are already at + .030
1) bore and sleeve the bad cylinder bore ,reuse the .030 pistons ( unless I find then faulty)
2) bore the 8 cylinders to .060 and buy new pistons
Old Jul 9, 2009 | 05:12 PM
Oldguard 7's Avatar
Oldguard 7
5k for a hunk of metal designed to 60's specs. You are simply paying for the" ZL-1 name. If you choose to go with an aluminum block I too would go with Dart, brodix. On the other hand if you are going to use the same internals I would look into the cause of the oil leak. Much cheaper than the ZL-1 block, especially if you are using the same internals. Either route you choose, good luck.
Old Jul 9, 2009 | 05:34 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I know that with an alu block I'll loose power ,I hear that quite often, and I don't necessarily dispute it, but I've never seen an A-B comparison to see how signicant that difference actually is. but being "european" I'm more intrigued by the weight loss than power. the GMPP alu block is not the stronger ( Dart, brodix....are a bit heavier but surely stronger) but weights just 110lbs. I would save 160lbs on the front of my car. I think the car would handle as I would like. The new block is a slight improvement over the old one (Not 60's technology, as some claim. The original ZL1 block was 90 pounds. The new is 110 pounds, as you mentioned.) I'm going with the new block in my '69. The 160# reduction in weight is about a 5% reduction in total vehicle weight, and it's essentially all off the front.
I vote for the new block, if it's available to you. Remember (without aerodynamic downforce), all the horsepower in the world won't get you around a corner fast. Lighter vehicle weight will.
Old Jul 9, 2009 | 07:49 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Recently installed one in my 67 and I like it just fine, NO, I LOVE IT! Bought it one piece at a time, brand new block from a machine shop before they did any work to it, got a good deal on it. Then bought all the other parts as I found them available on the internet, ALL new, ALL GM parts at a good price. I say go for it!
Rex
Old Jul 9, 2009 | 09:37 PM
Kid Vette's Avatar
Kid Vette
Rex
That is sweet lookin'. Not a real Traco I assume?
To new ZL1 block. advises?
Old Jul 9, 2009 | 09:49 PM
Dr L-88's Avatar
Dr L-88
Sorry, didn't mean to hijack ELLE88's post. Unfortunately the ZL-1 is not a product of TRACO, but this one is................I was originally going to "de-tune it" and put it in my 67 and then the ZL-1 came along, so......................the Traco engine had to wait a while longer for its new home, but someday....................
Old Jul 10, 2009 | 02:07 AM
Solid LT1's Avatar
Solid LT1
The GMPP block was made due to demand by vintage Can-Am racers for a replacement of their aging ZL-1 parts. There are soemadvantages to using a Dart, Brodix, Rodeck blocks are all stronger pieces that even the later design GMPP aluminum big block. The iron block in you L-88 would probably accomodate a 0.100 to 0.125 (2-3MM) overbore based on it being a 4 bolt main HP factory block (they usually have pretty thick cylinder walls on the 4 bolt castings.) The block can be checked with a sonic tester for casting thickness by a racing engine rebuilder. Iron engine blocks have been know to be more stable and will generally make more power than a aluminum motor. One advantage to going to a aftermarket engine block would be the ability to make a 4.40" (111mm) bore motor with ashort stroke crank. Back in the 60's Bruce McCLaren was testing the 510cu/in Can-Am Chevy motor (went over 212MPH at Riverside raceway in Los Angeles, CA) and demanded they replace that "monster" with his much preferred 4.40 boreX3.5625 stroke 430 motor that he ofeten said was his favorite Can-Am motor.
Old Jul 10, 2009 | 06:20 AM
elle88's Avatar
elle88
I'm quite sure... Zl1
now I have to find $$$ quickly ( I don't have the $$$ tree! ) because I would like to do the job in august ( too hot here for enjoing a BB car ) and have everything ready by early september.
I think I can sell the 68 block and get back some $$$ too. does someone have an idea of the market value of my block? 1968 CE852797 marked replacement block , 4 bolts, +0.30 . I can't find any on ebay to have just an idea...
but I could keep the block too for other projects...
so Solid LT1 , the problem of sleeving a cylinder bore is to have enough meet to overbore , right? Hmmmm you make me think...just in past days a friend of mine has sleeved 2 cylinder bores on a 454 2 bolts , but he has bored more than what you say being safe and then bored the sleeves to +0.30 . there was a cyinder crack in one cyl , the other had a small hole. should my friend fear possible engine failure?
