Fan Clutch
Old Jul 8, 2009 | 06:42 PM
temvette72's Avatar
temvette72
Default Fan Clutch
What are the symptoms of a failing fan clutch? Mine has a little play in the hub and the fan free-wheels for several seconds after the engine is shut down. Thanks!
Temvette72
Old Jul 8, 2009 | 06:50 PM
JimT's Avatar
JimT
I don't think there should be any "play" in the fan clutch. Mine doesn't and it doesn't spin after the engine stops.
Old Jul 8, 2009 | 06:58 PM
...Roger...'s Avatar
...Roger...
Buy this one #88961768 its a good one.
Here is some info in this thread and a couple links to threads where this clutch was discussed. Hope this helps.
http://forums.corvetteforum.com/c3-g...-question.html
Old Jul 8, 2009 | 07:13 PM
1nicecorvette's Avatar
1nicecorvette
no play in the clutch at all. make sure its the clutch and not the water pump bearing gone bad. the fan should stop right when the car is turned off maybe a half turn after. also look for leaking silcone fluid coming out of the shaft area sure sign its gone.
Old Jul 8, 2009 | 10:09 PM
temvette72's Avatar
temvette72
Sounds like I need a new one! At least it is a relatively cheap and easy fix. Thanks all!
Temvette72
Old Jul 8, 2009 | 10:18 PM
Aruba1's Avatar
Aruba1
Can't you drill a hold and refill it with silicon then plug the hole??? Just wondering
Old Jul 8, 2009 | 10:50 PM
eagle275's Avatar
eagle275
Default Not butting in..
but what about that fan clutch eliminator? Any ideas about that?
Old Jul 8, 2009 | 11:11 PM
...Roger...
Direct drive ?
Old Jul 8, 2009 | 11:41 PM
eagle275's Avatar
eagle275
Default I don't know
here's a link;
http://www.ecklers.com/product.asp?p...9&dept_id=1252
Old Jul 8, 2009 | 11:45 PM
...Roger...
Your gas mileage would suck.
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Temvette72
you have defined it in your post.
Old Jul 8, 2009 | 11:48 PM
eagle275's Avatar
eagle275
ok DWncchs, I'll ask. Why? I'm not trying to be funny here, just curious.
Old Jul 9, 2009 | 12:00 AM
...Roger...
The stock fan really moves a bunch of air and running it direct is going to waste a lot of energy. The fan clutch slips when all that air is not needed.
Old Jul 9, 2009 | 12:01 AM
eagle275's Avatar
eagle275
Gotcha.Thanks!
To Fan Clutch
