Rag Joint from Riks Corvette parts?
Old Jul 8, 2009 | 10:20 PM
BIGJIM13's Avatar
BIGJIM13
Default Rag Joint from Riks Corvette parts?
Has anyone used the STEERING COUPLING FLANGE REPAIR KIT from Riks ?
is it any good...have the original rag joint, looks like my flange just needs replaced !
Old Jul 8, 2009 | 10:35 PM
mapman's Avatar
mapman
No experience with their repair kit. I purchased a new one (GM) from my local Chevy dealer. Not that expensive and seemed easier to me.
Old Jul 8, 2009 | 11:23 PM
stock76's Avatar
stock76
Most of the rebuild kits are junk. You are better off (and safer) buying an OEM steering coupler (rag joint). This is not a part to economize on. Scroll down to the steering coupler articles and do a little reading. http://jimshea.corvettefaq.com/?page_id=4. There is also a great how-to article on removal and repacement.
The GM part number is 7818568. Still available through your local GM dealer or from a number of supporting vendors on this website or from GM Parts Direct. Do a search, you should be able to find one for between 80 and 100 dollars depending on the supplier.
Old Jul 9, 2009 | 07:33 AM
glassman74's Avatar
glassman74
with 76
Old Jul 9, 2009 | 08:10 AM
BKarol's Avatar
BKarol
Not to steal the thread but could someone who states the replacement is junk please post their experience. Pics would help. How many miles did it fail, what happen, etc.
Old Jul 9, 2009 | 09:55 AM
Jim Shea's Avatar
Jim Shea
Here is an address for a word document as to my concerns about rebuild kits.
http://jimshea.corvettefaq.com/wp-co...srev05jl07.doc
Jim
Old Jul 9, 2009 | 10:56 AM
wytevette's Avatar
wytevette
I just ordered a rag joint repair kit from Willcox last weekend, and it should be here in a couple days. No experience with them yet.
Old Jul 9, 2009 | 10:58 AM
BKarol's Avatar
BKarol
Thanks Jim, I previously downloaded and printed your articles
I think the OP and myself would like to hear from owners who did use the kit. You state in your article you can use the kit just use the original bolts, etc.
Anyone try the kit the op asks about? what has been the result? Has it come apart?
Old Jul 9, 2009 | 12:23 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I got my rag joint as a whole assembly from GM Parts Direct, a genuine GM part.
Old Jun 14, 2011 | 04:33 PM
polyrocks's Avatar
polyrocks
RockAuto appears to have the part as well. For 17bucks I just ordered one for my 67. If you google Lars 202 which is the part number you should get to an Adavance Auto parts page with reviews... Just an option that appears better than the rebuild kit.
Old Jun 14, 2011 | 08:18 PM
7T1vette's Avatar
7T1vette
Rik's repair kit is the laminated rubber coupling, new attaching and locking bolts/nuts/lockwashers for $12. I've bought a lot of stuff from Rik's and don't think he would knowingly sell any junk. It may be the same rubber coupling as GM sells...who knows? If you don't need to replace any of the 'hard' components, why not?
Old Jun 14, 2011 | 11:22 PM
polyrocks's Avatar
polyrocks
Should have been more clear... By better I mean that it comes as a complete unit with what appears to be the stock type rivits, etc. Saves me the hassle for for a few extra bucks = better in my book I have no reason to believe it is better or worse than the rubber rebuild kit. Just another option...
Old Jun 15, 2011 | 01:12 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
They are not that hard to install, not 100 percent correct but compared to the entire joint a cheaper alternative. The bolts and rivets are a pain.
Old Jun 15, 2011 | 07:37 AM
71scgc's Avatar
71scgc
Still no ground strap...
Old Jun 15, 2011 | 11:12 AM
7T1vette's Avatar
7T1vette
Geez.... Go buy 3" of braided copper ground strapping and run it from one side of the coupling to the other. Put it on the bottom side if you don't want to see it.
Old Jun 15, 2011 | 01:17 PM
...Roger...'s Avatar
...Roger...
It's only a ground path for gosh sakes.
To Rag Joint from Riks Corvette parts?
