Starter Question
Old Jul 11, 2009 | 11:14 PM
uncle phil's Avatar
uncle phil
Default Starter Question
I just got my first Vette (1979 L-82) a few weeks back. I have noticed when I go to start it, I hear a "sparking" sound at times. It usually is slow to crank when this happens, and has not cranked a couple of times.
My brother used to own this Vette, and he says there may be a loose wire on the starter where it does not have a good connection. I'm thinking maybe a ground strap.
Anyone familiar with this that might have some suggestions ??
Thanks!!!!
Phil
Old Jul 12, 2009 | 08:19 AM
mikep3's Avatar
mikep3
Be safe, when working on the starter always disconnect the battery.
Check, clean and tighten the starter connections, checking the Pos & Neg connections.
Replacement starters can be had at any Auto Store, NAPA-Autozone-Advanced, etc for under $100 and Mini starters $175.
Good luck.
Old Jul 12, 2009 | 09:27 AM
69small block's Avatar
69small block
Good luck.
Old Jul 12, 2009 | 09:58 AM
uncle phil's Avatar
uncle phil
Thanks !!!
Old Jul 12, 2009 | 07:24 PM
Ironcross's Avatar
Ironcross
clean the battery POS/NEG battery connections. Especially the negative ground connection at the frames transmission crossover right under the battery. No body ever cleans that connection and your describing conditions caused by it....
Old Jul 12, 2009 | 08:55 PM
TimAT's Avatar
TimAT
and the cable that runs from the right frame motor mount to the block.
Old Jul 12, 2009 | 10:01 PM
uncle phil's Avatar
uncle phil
This sounds simple enough. I sure appreciate the info.
Phil
Old Jul 13, 2009 | 09:54 AM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
I had the slow cranking, and stomach sinking feeling of being in some strange place and feeling like I wasn't going to be able to get the car started again, not fun. On mine, it turned out that someone had boogered up the threads on the solenoid real good such that the connections were not tight and solid. I think it was like $20 for the new solenoid, the starter itself was fine. Since I replaced the solenoid, I have not had the problem again (knock wood).
Old Jul 13, 2009 | 11:13 AM
7T1vette's Avatar
7T1vette
Possibilities are: loose power cable to starter solenoid; loose grounding cable; damaged/defective/worn-out contacts in starter solenoid; worn-out brushes in starter; internal shorting of components inside starter [one of the two casing retention bolts comes very close to one of the brushes...improper assembly could cause those to arc].
If you check out the cables/connections and can not determine the cause, I suggest that you drop the starter and solenoid and inspect them internally for your problem. They are relatively easy to disassemble and inexpensive to rebuild...if you do the work. You can buy new brushes for the starter and a rebuild kit for your solenoid at NAPA stores.
Old Jul 14, 2009 | 10:27 AM
uncle phil's Avatar
uncle phil
I think I found my problem. I went under the hatch and addressed the battery first. This car has a power disconnect switch on top of the battery. I got checking, and the connection was loose. Also a loose connection on the positive terminal. I took all connections apart and cleaned. I also bought a new terminal for the positive side. Re-stripped wires to make a better connection, and then tightened them all down properly. Car is firing up now without any hesitation. If it keeps doing this, then I guess I found my problem. Thanks to everyone for all the suggestions that helped to get me thinking and checking the proper places.
Phil
To Starter Question
