Switch on steering column
Old Jul 13, 2009 | 10:53 AM
sstopczy's Avatar
sstopczy
Default Switch on steering column
There is a small black switch on the underside of the steering column, what it is for?
Old Jul 13, 2009 | 11:04 AM
OMF's Avatar
OMF
That could be the overide switch for the headlights. Pull it and the headlights should pop up.
Old Jul 13, 2009 | 11:41 AM
70Donnybrooke's Avatar
70Donnybrooke
When I hear him say "switch" I istantly thought maybe the 4 way flashers.
Old Jul 13, 2009 | 12:38 PM
BHRIG's Avatar
BHRIG
Describe or show picture of where it is located.
Old Jul 13, 2009 | 12:51 PM
Peterbuilt's Avatar
Peterbuilt
Could it be the "Trip" odometer reset ****? PG.
Old Jul 13, 2009 | 09:48 PM
chucks's Avatar
chucks
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
Could be a kill switch.
Old Jul 14, 2009 | 10:35 AM
sstopczy's Avatar
sstopczy
I tried flipping it and a little blue light came on the tip of the switch. I don't think it does anything. Thanks for the responses, I wasn't sure if I wanted to flip it or not.
Old Jul 14, 2009 | 09:16 PM
1nicecorvette's Avatar
1nicecorvette
you may want to trace and see what its connected to. if its something that should be on and isnt it could be safety issue if its something that is on already and shouldn't be could be a fire or battery drainage problem. no corvette had any switch mounted to the lower column.
Old Jul 14, 2009 | 09:57 PM
BHRIG's Avatar
BHRIG
Possibly there was a set of fog lights in your car's past.
Old Jul 14, 2009 | 10:35 PM
Solid LT1's Avatar
Solid LT1
The EJECTOR SEAT! Make sure it is set to the passenger side and the top is off before testing! Two switches, I can think of offhand, the 4way emergency flashers (below the ignition key) or if it is further up below the column where it enters the dash and your Vette is a 68-72, the round **** is for the windshield wiper motor cut-off to allow changing wiper blades.
Old Jul 15, 2009 | 06:23 PM
RHD '68 L89's Avatar
RHD '68 L89
No factory switch had a blue light in it, someones put it there. Now you have to figure out what it does, or used to do.
To Switch on steering column
