Need help with electrical problem
Old Jul 15, 2009 | 11:22 PM
jrmartin81's Avatar
jrmartin81
Default Need help with electrical problem
My altenator on my 81 is charging like 37 volts and the battery light is on and it is not getting the charge to the battery.What the heck is wrong?Almost burned some of my wires up.
Old Jul 16, 2009 | 01:59 AM
GunPowder's Avatar
GunPowder
sounds like your regulator is toast.
There are some methods to identify a toasted regulator (refer to a workshop manual). I am not familiar with the later alternators but the earlier regulators can be replaced/repaired without buying a new alternator.
Old Jul 16, 2009 | 07:14 AM
jrmartin81's Avatar
jrmartin81
Well that has already been tried.we changed out the alt. twice still 37
volts.is it possible that the hot wire going from the alt. to the bat. is grounded some were?
Old Jul 16, 2009 | 08:04 AM
...Roger...'s Avatar
...Roger...
37 volts that's a lot
Old Jul 16, 2009 | 08:26 AM
GunPowder's Avatar
GunPowder
interesting
A short on your main hot wire should melt your cable or spark somewhere.
Did you check the alternator/regulator outside the car (not connected to anything) - just to exclude a problem with your harness.
Old Jul 16, 2009 | 09:30 AM
wombvette's Avatar
wombvette
I doubt 37 volts is possible with a car alternator. I think you should check your meter. Full output on most alternators wouldnt be more than 16-18 volts.
Old Jul 16, 2009 | 11:22 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
Agree maybe 37 amps , but not volts . unless you are ready yourmeter on the wrong scale! Ron
Old Jul 16, 2009 | 11:28 AM
KB9GKC's Avatar
KB9GKC
Old Jul 16, 2009 | 12:23 PM
7T1vette's Avatar
7T1vette
It sounds to me like the wiring to the alternator is not hooked up correctly. Some replacement alternators require reversing a couple of the wires going to it. Verify that you have followed the installation instructions...assume nothing.
Old Jul 16, 2009 | 02:25 PM
stellar's Avatar
stellar
wire from alt to bat is open, not grounded. run a wire from alt to bat and check voltage. Just do this a quick test. don't leave it that way.
To Need help with electrical problem
