What should oil temp be on
Old Jul 16, 2009 | 12:48 PM
cargo247's Avatar
cargo247
Default What should oil temp be on
stock 81 350 running 20w50 60 deg day , doing 70mph, at engine coolant temp 210 deg
oil temp was 250?
Todd
Old Jul 16, 2009 | 02:35 PM
cargo247's Avatar
cargo247
anyone?
Old Jul 16, 2009 | 04:12 PM
Spocc's Avatar
Spocc
i run 10w30 & it runs at 195
oil pressure is around 40psi
maybe i should switch to 20w50 for the summer?
Old Jul 16, 2009 | 06:22 PM
gingerbreadman1977's Avatar
gingerbreadman1977
mine sits on 200 and when im thrashing it can go up to 240
Old Jul 16, 2009 | 07:03 PM
FB007's Avatar
FB007
oil temp was 250?
Todd
Oil usually runs 20* above coolant temp. Higher under high load, such as high speed, uphill, towing, etc. 250 seems high for what you are describing.
Old Jul 16, 2009 | 09:15 PM
cargo247's Avatar
cargo247
Thanks all its running at 40psi as well and it is mobile 1 synthetic any reason why ???
Todd
Old Jul 16, 2009 | 09:35 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
You do understand that oil does as much cooling as it does lubricating. Unless you have a separate oil cooler, the only cooling it would get is from the cooling system. It therefore would be higher temp than the coolant. 250 oil versus 210 coolant does not seem out of line to me.
JMO
Old Jul 16, 2009 | 10:22 PM
alswagg's Avatar
alswagg
my 81 runs 220 degrees at 2,800 rpm, this is 72 mph. I run 15w40 synthetic. engine temp is 195 degrees.
Old Jul 17, 2009 | 06:08 AM
noonie's Avatar
noonie
The viscosity of oils is rated by SAE and they, in their infinite wisdom, say that the normal operating oil temp is 100°C or 212°F and it is at that temp they test for the rating.
Old Jul 22, 2009 | 07:22 AM
cargo247's Avatar
cargo247
so if it is 212f and my temp stays up there how long will my oil last?
Old Jul 22, 2009 | 07:35 AM
baxsom's Avatar
baxsom
that depends on the type of oil and how long it is being thrashed as well as any blow by or fuel in the oil.
only by sending out a sample to a test lab will tell you how long it is good for.
when you change the oil you send them a sample, they will tell you all the contaminants in the oil as well as the overall condition of the oil itself. most people that i know that have ever sent in a sample found out that they changed their oil too early and could have driven on it another 3 or more thousand miles before the oil lost its ability to protect.
Old Jul 22, 2009 | 07:48 AM
Ganey's Avatar
Ganey
Oil temp. about + 25* over coolant temp.
Old Jul 22, 2009 | 10:38 AM
gkull's Avatar
gkull
oil temp was 250?
Todd
I'd verify that with a heat gun on the side of the oil pan. run it hard and then pull over and get a reading. At some point over 250 the oil starts to break down.
Your cooling system is marginal to get that hot just driving down the road at 70
Old Jul 22, 2009 | 02:24 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Ideally, you'd like your oil quickly warm to just over 212 degrees and stay there. 212 will vaporize the liquid water, a byproduct of blowby, and this vapor can be cycled out of the engine via the PCV system.
Also, hot oil lubricates better than cold oil.
Not sure why some of you are running 40w and 50w vis. That's a needless drag on the engine. How about a good quality 10w-30?
Old Jul 22, 2009 | 04:10 PM
jb78L-82's Avatar
jb78L-82
My 78 L-82 use to run about 225 degrees water temp and 250 on the highway (I have an 80 oil temp gauge in place of the clock which I installed 25 years ago) with the OEM cooling system (radiator, shroud, fan clutch, water pump). I installed a Dewitts aluminum radiator, Stewart aluminum stage 2 water pump, High performance Robershaw 180 thermostat, new correct hoses, etc about 2 months ago, and the car now runs about 170 around town and 180-185 on the highway with the oil temp running about 200 on the highway as well. As an aside, conventional oils start to breakdown around 250 degrees while synthetics have a much higher resistance to breakdown at about 325 degrees. Another reason to run a synthetic oil to help with the cooling!
Old Jul 22, 2009 | 08:15 PM
cargo247's Avatar
cargo247
Thanks everyone all good points i have a heat gun and will do just that a good hard run and shoot the pan see how it is.
now only if it would stop raining.
Todd
To What should oil temp be on
