Vibration
Old Jul 17, 2009 | 08:28 PM
ALOHA73's Avatar
ALOHA73
3rd Gear
Default Vibration
Got a new vibration that just started. Seems my 73 vibrates when any torque is applied positive or negative. goes away if coasting or not under load any help would be greatly appreciated. has 3 speed auto if that matters thanks.
Aloha 73
Old Jul 17, 2009 | 08:50 PM
dannyman's Avatar
dannyman
You need to check the driveline.
Begin with all the u-joints: and then see if there is any indication that you may have lost a balance weight on the driveshaft.
Check the halfshafts to see if there is any evidence of impact damage.
Let us know what you find.
Old Jul 17, 2009 | 09:01 PM
ALOHA73's Avatar
ALOHA73
3rd Gear
Default thanks
I'll start there, Thanks
Old Jul 18, 2009 | 04:17 PM
ALOHA73's Avatar
ALOHA73
3rd Gear
U-Joints it was. Thanks again
ALOHA73
Old Jul 18, 2009 | 08:31 PM
dannyman's Avatar
dannyman
ALOHA73
Glad you found it!
Old Jul 18, 2009 | 09:00 PM
1nicecorvette's Avatar
1nicecorvette
for us that dont know. how did you know it was the u-joint that was bad?
Old Jul 20, 2009 | 11:00 PM
my 76 ray's Avatar
my 76 ray
Turn the wheel while looking at the U Joint. There should be no play in the joint.
To Vibration
