Engine tuning almost finished !!!
Old Jul 20, 2009 | 07:42 AM
73StreetRace's Avatar
73StreetRace
Default Engine tuning almost finished !!!
I think this time I'm finished with the tuning of my engine !!!
First, specs :
350CI- L82 - 1973 - Manual transmission
Intake manifold : Holley Street Dominator ( single-plane )
Carburetor : Holley 0-4776-S ( 600 CFM double pumper ), Stock jets : 122-66 & 122-73, 2 pink pump cams, nozzles : 28 & 32
Stock heads, but ported, and it seems that I have Bee-Hive springs on them, so I don't know what else had already been changed...
Stainless steel headers and exhaust lines ( 2,5" )
Camshaft : Unknown, but hydraulic lifters.
Tuning helps : Innovate LM-2, G-Tech SS
Recording : AFR, RPM, MAP, TPS.
And now, the pictures :
MAP sender :
TPS Sender :
LM-2 & G-Tech :
Here is the result of my ( long ) investigation :
- The single plane intake manifold was way too hot for Summer. So the exhaust crossover has been TIG welded, fully closed. Sorry, no pictures !
- The stock carb gasket wasn't thick enough, causing fuel vaporlock in Summer at very low speeds.
This has been fixed with a sandwich made of two gaskets with a large aluminum sheet between them, acting as a heat sink ( Hood clearance is low ! ). Easy, but really effective :
- The old air filter ( Edelbrock 1002 proflow, see below... ) was too restrictive, causing power loss and a rich AFR at high RPM + high load conditions :
A KNN air cleaner solved the issue :
I made my own aluminum stubstack, and adjusted it with the TRANSDAPT air filter base :
I milled the choke tower, too :
And now the results :
- I was a little surprised, but the stock main jets were pretty close to perfection. Only the secondaries were a bit lean. One size bigger was enough to reach optimum AFR.
- On the contrary, the squirters ( primaries : 28 and secondaries : 32 ) were really too small for my application... Even with the strongest pump cams. Single plane manifolds really like an early big shot !
So I purchased two "tube type" 0.035" discharge nozzles for both primary and secondary, and used the orange cam on primaries and green one on secondaries.
The transition is now really smooth between cruise circuits and main jets, and I get 11.6 < AFR < 13.0 during the transition ( about 0,3 second ).
( AFR was more than 16.0 with the stock pink pump cams and nozzles, causing serious bogs and sometimes backfires ).
Primaries didn't need all the pump capacity, but the secondaries almost did.
- Stabilized AFR at WOT is now : 12,8 at 3000 RPM and close to 12,4 at 6000 RPM ( outside air temperature = 77°F )
I tried main jets one size bigger and one size smaller, but power seems lower in both cases.
- Stock power valve is rated at 6,5" Hg and seems to work great like this, but I didn't try others, so I can't be sure it's the best one...
- Total timing is set at 37° BTDC, all in at 2800 RPM. Vacuum advance is 15° at 10" Hg ( on manifold vacuum ), centrifugal advance is 20°, idle at 1000 RPM ( engine pulls 13" Hg vacuum ).
I didn't try yet to change timing and see how it affects engine power and torque ( recorded with the G-Tech ), but I think it will be next and last step
- Oh yes, one more thing : it seems that engine power hasn't yet reached its maximum at 6000 RPM ( power curve still rising ), but I don't want to rev it higher :
Hydraulic lifters, MSD-6AL limiter set at 6200 RPM and maybe soon limited by carb cfm...
Old Jul 20, 2009 | 08:47 AM
Fishndude's Avatar
Fishndude
I like the gauge arrangment and location.. Maybe I will move my Tac and shift light like yours. Right now they are a little to close to my wheel.
Looks like someone has alot of work into those stock heads.. Just curious, can you post more about the heads like chamber size, valve size and were they opening up from stock?
What does the short block consist of? and have you had a chance to test drive it yet?
Lokks great
Old Jul 20, 2009 | 09:25 AM
billla's Avatar
billla
St. Jude Donor '14
That is some outstanding work!
Old Jul 20, 2009 | 09:35 AM
73StreetRace
Sorry, but I don't know much about the history of the heads. Never removed them. Maybe one day
But I'm going to remove some valve springs in a few days to see what kind of valve stem seals I have ( they are not stock, look like rubber with teflon insert ) :
However, I can show you two more pictures of the gauges if you want :
Gauges seen from the driver seat :
Old Jul 20, 2009 | 10:08 AM
halfshaft's Avatar
halfshaft
I have been working on these same things. Is 12.8 AFR optimum for HP? Where is your AFR at cruise? Could you post a log from the LM2 for me to look over? And don't overlook timing, it plays a big role in tuning.
Old Jul 20, 2009 | 10:35 AM
73StreetRace
As far as I know, most engines make maximum power with an AFR between 12,6 and 12,8 as a rule of thumb.
But actually, the optimum AFR is a curve, depending on RPM and engine modifications.
These are the values I found in a Holley tuning book :
Standard Engine Optimum AFR ( WOT ) :
1000 RPM -> 13,9
2000 RPM -> 12,9
3000 RPM -> 12,5
4000 RPM -> 12,5
5000 RPM -> 12,45
Slightly Modified Engine Optimum AFR ( WOT ) :
1000 RPM -> 13,3
2000 RPM -> 13,1
3000 RPM -> 12,45
4000 RPM -> 12,4
5000 RPM -> 12,3
6000 RPM -> 12,25
For a race car, AFR is even richer. However, I think these values are on the rich side ( no chance to melt a piston ! ). My experience is that 12,5 -12,8 seems to make a little more power. The fact is, with colder temperatures, air density increases, and AFR moves to the lean side ( about 0,2 AFR variation each 9°F ). Hygrometry and air pressure also affects AFR. So jetting can be perfect only in very precise atmospheric conditions. This is where fuel injection exceeds carburetion.
The best way to know which AFR value is the best for your engine is a dyno test or a 1/4 mile run...
About the AFR at cruise, I get between 13.0 and 13.5. This is of course a little rich, but all double pumpers are built like this.
They are not economy carburetors, their purpose is not to save fuel, but to make power.
I still have to record some logs with the LM-2 and I will post a log file ASAP. Keep tuned.
Old Jul 20, 2009 | 12:18 PM
halfshaft's Avatar
halfshaft
So a little rich in this hot weather should be close to optimum when cooler temps arive. I am cruising at 13.2 to 13.6 as I thought this was rich I was just wanting to compare and see if it was the norm for a dp. I have recently dove into the LS1 tuning world and some of the tuning translates over to carbs, but the LS and a carbed small block are totally different beasts. I logged some 1/4 mile runs yesterday. I'll try to get them posted tommorrow.
Old Jul 28, 2009 | 04:59 AM
73StreetRace
So, here are the final results :
The following picture shows a pull in second gear from 2600 RPM to 5800 RPM.
The two horizontal lines are 12.5 and 12.8 AFR marks.
The green plot is TPS and the red one is MAP ( both with some noise, caused by the extreme sensibility of the LM-2 ).
Note that the MAP sensor was not not perfectly calibrated the D-day, so 1,7" Hg vacuum is actually atmospheric pressure
No plots are smoothed. I tried every cam, even the biggest for 30cc pump ( blue ) and I still have a slight peak when TPS goes to WOT.
It's the same ( worst ) with bigger nozzles ( I tried 0,040 and 0,042" ).
I think it takes some time to vaporize the fuel discharged from the nozzles, but air arrives instantly with a double pumper. This is the best configuration I have found. Acceleration is very clean, no bog, no noticeable hesitation at any time. The green, red and white cam were too bumpy, the pink and orange one not enough.
I slightly modified the white cam so it has a shape between the green and the pink cams.
Speed at 6000 RPM ( 2nd gear ) is 87 MPH. I made 3 or 4 other pulls, with the same consistent results. Outside air temperature was 79°F during the recording.
If someone wants the .log or .d32 file ( full length : 11 minutes ), send me a PM...
Old Jul 28, 2009 | 05:23 AM
baxsom's Avatar
baxsom
to quote marty mcfly
"It looks like Darth Vader's bathroom."
Old Jul 28, 2009 | 06:55 AM
73StreetRace
Didn't know this one
Old Jul 28, 2009 | 07:07 AM
baxsom's Avatar
baxsom
back to the future, come one i cant be the only person that watches too much tv
Old Jul 28, 2009 | 07:10 AM
bluzman2004's Avatar
bluzman2004
Where did you get that strap thing to mount your shift light?
Old Jul 28, 2009 | 07:55 AM
73StreetRace
It's a "home made" stainless steel necklace. I used a tape of rubber ( inner tube ) between the steering column and the necklace.
This helps to prevent scratches on paint, dampers vibrations transmitted to the instruments and also prevents them from moving.
The necklace has been sandblasted and painted ( black ) :
I made one for the tachometer too ( the middle part is made of aluminum ) :
Old Jul 28, 2009 | 10:43 AM
not a '76's Avatar
not a '76
Knowledge is Power!
I think its awesome that your using modern information to tune the heck out of your carburated motor. I hope the trend becomes overwhelmingly popular in the future.
Old Jul 28, 2009 | 10:59 AM
bluzman2004
Nice design and drawings, too! Good job your tuning.
Old Jul 29, 2009 | 12:13 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Mine runs around 13.5 at cruise, these Gen 1 motors like it rich especially if you have them slightly modified. I can set it to run anywhere I want, 15:1 if I want but the motor doesn't like it and I get lean misses.
My tach is moved closer to the steering wheel, believe it or not my tilt / telescope still works and my hands never hit the tach
BTW nice job on everything you've done
Old Jul 29, 2009 | 01:17 AM
73StreetRace
Thanks MotorHead !
I think the steering column was much longer in the oldest C3, and the stock instruments were deeply "inlaid" in the dashboard, so it was certainly easier for me to fit in a huge tachometer...
BTW, awesome Vette you have, too
Thanks everyone for the compliments !
To Engine tuning almost finished !!!
Old Jul 29, 2009 | 09:18 AM
bluzman2004
Just some more experience info with A/F ratio. Same as Motorhead said, I found mine (almost the same motor) likes to cruise a 13.5 or so. I can cruise at 14.7 with a push of a button, but you can just tell isn't happy. What I've found on the dyno with some really top notch builds (Nascar) is that the more efficient the heads, the leaner they make peak power. I've seen motors make best power at 13.5 and was amazed actually. These had very good heads though. Most of our "street heads" are not that good and will like 13.0 to 12.5 depending on your combustion chamber and piston type (flat or domed). Domed usually hurts efficiency some.
Old Jul 31, 2009 | 12:31 PM
halfshaft's Avatar
halfshaft
You can't always trust Holley's chart on the pump cams. I set up a dial indicator and checked the lift at the pump diaphram. I found drastically different lift and duration than they advertise. If I remember correctly I ended up going with the green cam. Large shot initialy and almost no movement once the secondaries start to rotate. This solved my initial lean spike. I've got all this data on paper and plan to put together a spreadsheet on it.
Old Jul 31, 2009 | 01:14 PM
73StreetRace
Actually, the green cam was the first I tried, and I still had the same lean pike, immediatly followed by a very rich pike ( 10,0 AFR ).
However, If I depress the throttle pedal slightly slower, or if i punch it at a higher RPM, the lean pike is much smaller.
I would be interested in your data. Thanks for sharing !
