Gas Gauge
Old Jul 20, 2009 | 01:21 PM
76yellow's Avatar
76yellow
Default Gas Gauge
How can I check my fuel sender at the tank. I did the ohm meter reading at the sender terminal & ground. I get nothing. I have 2 senders, a new one in the tank & one on the bench & get no reading on either one. Am i doing something wrong or are they both junk ?
Old Jul 20, 2009 | 02:55 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you to this link, there is a step by step manaul on testing everything fuel gauge related on your car.
It will only be up on the help repair side for free to forum members until the end of this month, so snag a copy!
http://willcoxcorvette.com/repairand...lp.php?hID=276
Old Jul 25, 2009 | 05:21 AM
70454's Avatar
70454
Thanks for posting these troubleshooting sheets. My fuel gauge is stuck at 1/4. From these instructions, it looks like I have a bad resistor. Where can I find one?
Thanks in advance.
Matt
Old Jul 25, 2009 | 05:07 PM
0Willcox Corvette
Former Vendor
Thanks in advance.
Matt
Matt,
If you pull the gauge out of the car and find the resistor is defective, you can purchase a 1 watt, 90 ohm resistor online or from Radio Shack. You'll have to solder some loops on the end of it, but it will work just fine. I'm sorry, I do not have any extras to send you.
Willcox
Old Jul 25, 2009 | 06:14 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Similar topic for Wilcox - pulled my tank & sender. Everything was OK before, but this is a 30 yo sender. Would it be best to replace it now? BTW 79
Old Jul 25, 2009 | 06:27 PM
0Willcox Corvette
Former Vendor
Not really, If the system is working fine I would leave it alone and just test it before you install it back in the car! . The senders from time to time will go bad, but in most cases the problems in your cars are wire problems.
I have some help pages for the both of you on the site. One for 1968-1976 and one for 1977-1982
http://willcoxcorvette.com/advanced_...&keywords=fuel
Willcox Inc.
Old Jul 26, 2009 | 12:20 AM
ratflinger's Avatar
ratflinger
Thanks. That document looks very helpful. I'll just clean my tank & reassemble. (after verification of course)
Old Jul 27, 2009 | 05:25 PM
0Willcox Corvette
Former Vendor
I think you'll be fine. Just test before you install.
Willcox
To Gas Gauge
