Radiator replacement
Old Jul 21, 2009 | 10:01 PM
dgrinde's Avatar
dgrinde
6th Gear
Default Radiator replacement
I have a 79 with a stock radiator 2 core, corvette america has a 4 core radiator that is twice as thick for 400 dollars. what are your thoughts? My car runs at about 265 on the freeway.
Old Jul 21, 2009 | 10:31 PM
MN80Vette's Avatar
MN80Vette
I have a 4-row core aluminum radiator (not from CA) in my '80 with a GMPP 350 HO crate and electric-only fan. My temp gauge rarely goes above 200.
Old Jul 21, 2009 | 10:40 PM
dgrinde's Avatar
dgrinde
6th Gear
The one I was thinking about getting isn't aluminum
Old Jul 21, 2009 | 11:17 PM
gingerbreadman1977's Avatar
gingerbreadman1977
at 260 your engine is going to blow up . i think you have other issues as well as radiator problems. make sure you are in fact running 260 by crosschecking with another gauge and if you are that high then buy yourself a dewitts or the 4 core copper/brass radiator. i can only say i prefer copper/brass radiators because they last longer then alloy radiators , can be easily brazed if a repair is required and dont suffer as bad from electrolysis.
Old Jul 22, 2009 | 01:50 AM
pauldana's Avatar
pauldana
COOL!!! I have a 79 also! love my car... have a 400hp/tq engine and this is what I went with, Saved me big money over other units and looks AWSOME!
here is my thread, read it and make your own decisions.. p:-)
http://forums.corvetteforum.com/c3-t...nd-shroud.html
Old Jul 22, 2009 | 03:08 AM
73StreetRace's Avatar
73StreetRace
If your radiator is 30 years old, maybe the core is heavily clogged. So perhaps with just a brand new GM radiator your problem will be solved... I replaced mine 8 years ago with the same ( but new ! ) part, and it made a huge difference !
... Assuming your engine is stock...
Just my 2 cents
Old Jul 22, 2009 | 09:32 AM
Ganey's Avatar
Ganey
Check temp. gauge & lower rad. hose for collapsing. Rad. shops can rod out the rad.
Old Jul 22, 2009 | 04:39 PM
thegazman's Avatar
thegazman
Default thegazman
Here's my DeWitt's aluminum radiator with dual electric fans in my 79 L82. Runs 180 degrees. No problem with electroysis if the radiator is grounded. Aluminum seems to transfer the heat better
Old Jul 23, 2009 | 02:17 AM
dgrinde's Avatar
dgrinde
6th Gear
Well I just finished putting in a 4 core radiator. Now it looks like I might have to change the thermostat back to a 180 so I can get my temp back in the correct running range. I am very pleased to have this problem. FINALLY! Thanks for the input.
Old Jul 23, 2009 | 04:52 AM
gingerbreadman1977
which one did you go with?
Old Jul 23, 2009 | 09:53 AM
cam99's Avatar
cam99
Grounding the aluminum radiator is enough to stop electrolosys? I thought I read you may need a sacrificial node? anode or cathode, not sure which though.
Old Jul 23, 2009 | 04:29 PM
dgrinde's Avatar
dgrinde
6th Gear
I went with a 4 core brass/copper from a local radiator shop. The 3 core they had for $250 was wrong so I got the 4 core for the same price. What a deal.
To Radiator replacement
