Horn problems
Old Jul 22, 2009 | 09:10 PM
redbaronwww's Avatar
redbaronwww
Default Horn problems
I have no power at the horn contacts in the steering wheel. There is power at the horn relay and can bypass the switch to activate the horn. Any help?
Old Jul 22, 2009 | 10:06 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
You did check the fuse right?
relay is not getting the signal from the horn button.
go to the horn button 1 side should be 12volts.
relay and horn should click in when you close the circuit to the other horn button contact.
There is a smalll spring contact in the assy that fails frequently.
trouble shooting tip ~ unplug the horns, if the circuit is working properly,
in a quite enviroment (closed garage) you can hear the Horn relay click.
69VETT
Old Jul 23, 2009 | 07:47 AM
redbaronwww
I took apart the horn button down to the small spring and still have no volts at the spring. I even went a little further and checked for volts at the contacts below the "small spring" and still no power. All fuses look good, even though there isn't one marked for the horn. Is the relay in the circuit after the fuse box? Do I need to dig deeper into the steering column?
Old Jul 23, 2009 | 08:06 AM
Jim Shea's Avatar
Jim Shea
You didn't mention the year of your Vette or whether or not you had a T&T column or a standard (non-adjustable) type. It makes a difference if you need information on removing the steering wheel, trouble shooting the ground path, etc. Anyway, this paper is pretty generic for all C3 Vettes.
http://jimshea.corvettefaq.com/wp-co...osis13JN06.doc
Jim
Old Jul 23, 2009 | 10:45 AM
69Vett's Avatar
69Vett
what year, tilt or normal, and I was incorrect about the 12volts at the horn button,
I think the horn button goes to Gnd and turns on the relay.
so one side of the contacts should go to gnd,
when these are closed it should have Gnd. on both contacts.
69VETT
forbes's Avatar
forbes
use ur finger....
Old Jul 23, 2009 | 12:31 PM
redbaronwww
Thanks for the info all .... Jim whats is the web address of the pictures in your response. I have a 74 Vette with t/t column. I will try the jumpers at the relay but think the problem is in the column.
Old Jul 24, 2009 | 04:18 PM
redbaronwww
Thanks Jim, It's fixed. The relay I bought new turned out to be bad. Your info helped out alot to diagnose the problem.
To Horn problems
