Wrong Power Steering Pump?
Old Jul 23, 2009 | 09:24 PM
fantic's Avatar
fantic
Default Wrong Power Steering Pump?
I just built a new small block for my 77. I transfered my power steering pump from my old engine to my new one and the pullys don't line up. The pump needs to be shimed out about a quarter of a inch. If I do that the alt belt rubs the pump. Do I have the wrong pump or pump pulley? The crank and water pump pulleys are dead on. Also I'm not going to run the ac for now. Will one belt run the water pump?
Old Jul 23, 2009 | 09:54 PM
71rdster's Avatar
71rdster
Best guess is that you did not use the crank pulleyand other pulleys from your old engine, and more to the point, you didn't use a Corvette waterpump.
Old Jul 23, 2009 | 10:43 PM
fantic's Avatar
fantic
I'm using a corvette water pump. The water pump pulley and the crank pulley line up perfect. The alt and air comp also line up. Just not the power steering pump.
Old Jul 23, 2009 | 11:17 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Are you using the correct Corvette C3 pulleys, the spacing between the belt v grooves are different than ordinary 350ci pulleys
Old Jul 23, 2009 | 11:36 PM
fantic's Avatar
fantic
I know I'm using a corvette water pump. The pulley has the larger hole for the shaft and fits snug. All other pulleys line up but the power steering pump. I may not have the correct c3 pulleys but why is everything else good?
Old Jul 24, 2009 | 02:23 AM
killer454's Avatar
killer454
on my 1980 it runs a short belt for the altinater and only gos to the water pump pulley ,short belt.
altinator mounts on drivers side of car do you have the right brackets.
water pump pulley is a double groove pully ,altinator runs off one groove in water pump pulley.
Old Jul 24, 2009 | 07:57 AM
jackson's Avatar
jackson
Is the new build based on a genuine GM block? Which block? ... ie 350 or 400?
Did you transfer the ps pump OLD BRACKET too ?
Old Jul 24, 2009 | 08:46 AM
mikep3's Avatar
mikep3
Default Picture
How about a picture, My 78 has three pulleys.
A-Water pump, crank & Alt. close to engine
B-Water pump, crank & AC. middle
C-Crank & PS only, outside
Old Jul 24, 2009 | 10:21 AM
tonak's Avatar
tonak
I have the exact same issue. Best guess on my part is I switched to solid motor mounts that may have a thicker plate to the engine which throws the alignment of the mounting bracket off. Did some shimming with washers to get it aligned
Old Jul 24, 2009 | 10:45 AM
MotorHead's Avatar
MotorHead
The alternator belt is very close to the pump on mine, you need the correct C3 3 groove crank pulley that's my guess.
Old Jul 24, 2009 | 11:01 AM
noonie's Avatar
noonie
Anything is possible, but
The pulley is pressed on the ps pump. With a puller you can adjust the position of the pulley to line it up properly with the proper ps pump mounting brackets.
The clearance is tight and some pumps even came with a belt guide.
Using the shortest alternator belt will also move the alternator belt out of the way as long as you aren't using tall valve covers.
There is no problem with running one belt, but it would be a good idea to keep a spare and a couple wrenches in with the jack just for fun.
Old Jul 24, 2009 | 01:44 PM
fantic's Avatar
fantic
Thank's for the replies. I tried a shorter alt belt but with the tall valve covers I have to take off the alt to change the belt. I guess I can do that and shim the pump a little. Maybe pull the pulley out a little bit. A lot of work. I might go to salvage yard and look at different pulleys.
To Wrong Power Steering Pump?
