front spring advice
Old Jul 25, 2009 | 07:02 AM
killer454's Avatar
killer454
Default front spring advice
rebuilding my front end on a 1980,after putting passanger side back together noticed when i look from the front of the car the one i just put back together the spring dosnt have as much of an angle as to the one i did not mess with yet.
i lined it up to bottom control arm know it is in right their.
should i compress this spring again and get it to go back more at the top ?
thanks for the advice
Old Jul 25, 2009 | 07:10 AM
73convertible's Avatar
73convertible
Did you put the original spring back in or is it a new one? If it's the original, then I would make sure the spring is in the upper and lower pockets correctly and then I would try putting weight back on the front end and see how it settles.
good luck
Old Jul 25, 2009 | 07:55 AM
killer454's Avatar
killer454
yes its the original spring,i will try compressing it today to see if i can get it closer at the top.
Old Jul 25, 2009 | 09:01 AM
Fishndude's Avatar
Fishndude
Keep in mind there is a notch where the very end of the spring goes so even though your in the pocket, you may still need to rotate it to get the tip of the spring in that pocket.
Old Jul 25, 2009 | 10:59 AM
killer454's Avatar
killer454
yes i put the end of the spring in the correct pocket at the bottom control arm,but did not check the top of the spring for allignment.
i dont have an engine or trany in this car right now im rebuilding the engine so i had to buy a spring compressor for this job.
the problem is when i was putting this spring back in the tool draws the spring at an even level when it looks like it needs to kick in the upper frame at an angle,apperently i did not get it all the way in at the top.
my tool gos inside the the spring and has a plate that ataches under the lower control arm.
*should i compress this spring and then somehow try to pry the spring into the upper pocket???
thanks for the help
Old Jul 25, 2009 | 10:59 PM
72LS1Vette's Avatar
72LS1Vette
thanks for the help
The spring pockets aren't parallel so you have to nudge the spring a bit with a crowbar to get it to pop into the upper spring pocket. There is an inspection hole in the upper pocket. You should see the end of the spring covering ~1/2 of the hole if it is seated correctly. The Assembly Manual only mentions aligning the spring in the upper pocket so that is the spec that I used when putting in new springs.
Rick B.
Old Jul 25, 2009 | 11:05 PM
killer454's Avatar
killer454
thankyou very much i will redo this spring instalation tomorrow.
and take your advice and align spring to top pocket.
thankyou for the help
To front spring advice
