Not sure if this should be here or general. Mods can move if necessary.
BB owners.
What RPM do you normally shift at? If I'm not pushing it I normally shift around 3500 but if pushing it then 5-5500(max).
What RPM do you cruise at on the higway? Because of my 3.70 rear gears I have to cruise at 3000 at 62 mph (speed limit) in my top gear of 4th (so far). Will cruising at 3000-3500 all day on a LONG road trip hurt the BB? I'm thinking it can't be good for it
Again because of the rear end gears this is what I have to do. Just want to get a feel as to how soon I should buy that 5 speed
I have 3.36 in mine and don't like to drive it for more than about an hour at freeway speeds, so I tend to take side roads. It will definitely put more wear on the engine running at 3000 RPM for an hour vs 1500 RPM for an hour.
I always have the philosophy of do whatever to keep the revs down and still not lug the engine... I don't run my car hardly ever hard.. it is just a cruiser..
Original owner changed out the factory 3:70s for 4:56s. I feel sorry for OPEC so will not change the 4:56s till oil rebounds. 3900 R's at 60mph with the M21 so I keep the bank account from over-filling
They sell overdrive kits for muncies as an option also. I have either 4.11 or 4.56 rear end in mine, with the conversion I can run 3.90 roughly as a final drive ratio.
You just change the cluster gears and flip the 3/4th rod lever over, and you're good to go.
May be a bit cheaper than a new trans or rebuilding the rear end.
Here's example, probably cheaper if you look around, I can't remember who I bought mine from off hand, but they were really good, I can get a name/number if you want.
GM would not do any warranty work for oil consumption other than a leak if it used a quart in 500 miles.
How about 1qt. for 300 miles if cruising at 32-3500 or 1/4 qt if cruising at 28-3000? Does this make any sencse at alllll???
These guys were great and really know their stuff. If you give them a call they can tell you what you'll need, what ratio you'll be at, and any other advice to do it.
If I remember right when I did it, the cost of a new trans or having a new rear end setup was quite costly and this was a rather easy solution. Also as I have never tore a Muncie (or a any transmission) apart before, I was able to do it myself, was rather suprised how easy it was.
You may want to ask about a new circle gear and new speedo gear as well, cause it will throw your speedometer off some, but the guy I talked to at autogear.net knew which circle gear and what tooth speedo gear I needed with the change.
I have a 4.11 rear end and I love it. not so much cruising, just fun, but a 5 speed trans should be the way to go. unfortunately too expensive for me.
I already saw that autogear overdrive and it was already on my mind.
1ARace. what about the rpm drop between shifts in respect to M21?
do you feel fine with M21 overdrive in fast driving ( with many UP-down) shifts?Or the gears are too far one from the other?
this my main concern in going for M21 overdrive. price is fine in indeed
1st and 2nd is as normal, but when you hit 3rd it's basically like throwing it in 4th, and when you push it in 4th its like a continuation of 3rd kinda (well obviously it is, lol, but what I mean is the powerband difference).
I kinda like it though, because if I want to get on it I can run 1st/2nd out for quick jumps then hit 3rd to settle it down, however, if I want to keep on it I just run 2nd out a little longer before dropping 3rd (to keep the powerband more consistent), and when you drop 4th hang on!!, because there is almost no lag in the power band.
So yeah there is a small lag in the powerband between 2nd and 3rd, but not a big deal in my opinion. Overall i'm very happy with it, and I can at least get it down the highway now.
I have been meaning to make a new video, so I'll try to do it soon so you can hear the differences.
GR x MPH div/by .006 div/by 1/2 Tire Height = RPM
3.73 x 65mph div/by .006/by 13.5 =2993 RPM @ 65mph
Edit: However that is 1.0 gear ratio final drive, with .87 final drive ratio I 'believe' it will put you around 2600rpm@65mph. I'd call autogear.net guys to confirm that though, or someone else here can correct me if i'm wrong.
Thanx 1A. were you just guesstimating the 2600rpm@65mph or did you plug in a different # somewhere to get that? I will call autogear tomorrow if no one else chimes in here.
(2600 rpm is 87% of the 1.0 final drive rpm of 2993)
a video would be great. keep me posted when you do it.
the lag between 2nd and 3rd is possibly a problem... I have already troubles in downshifting 4 to 3 now, I suppose it will be impossible with the overdrive M21.
I'll study the thing...
Shmoky
with my engine which redline is 6500 rpm , I shift at 5000-5500 rpm which on the paper looks to be hi-torq point, so I keep a certain headroom from redline and possible miss , I sometimes miss the 3rd...
whith the new L88 engine coming soon, I'll probably have a 7000rpm redline . I'll check the torque and power graphs after dyno and see if I can shift at 6000rpm. But I don't have a rev limiter now, so I have to be careful
It's nothing to be that worried about to be honest. It don't take that long to get the feel of it, and it's not that much different than how it usually was.
But yeah, let me get a video together to compare the differences, then you'll see there's not much to worry about.
shmoky
If you are running 225/70R15 tires, which are actually 27.4" diameter, then you would be at 2566RPM@65mph. Just to be sure you are using correct tire size.
