Air filter power
Old Jul 27, 2009 | 01:24 AM
MNTWINS33's Avatar
MNTWINS33
Default Air filter power
Will i achieve more HP with an air filter with no case around it? I bought a charged air filter K&N to get a little more HP but its in cased in the dome...is there a difference?
Old Jul 27, 2009 | 08:22 AM
7T1vette's Avatar
7T1vette
If the filter elements are clean and properly sized, and the opening(s) in the air cleaner housing are adequate, there will be an insignificant difference in engine performance. If you were to dyno test those two situations, the actual change in performance would be masked by the precision error of the dyno machine.
Most air cleaner/filter selections are based on appearance...not on real performance gains.
Old Jul 27, 2009 | 09:10 AM
a1sensei's Avatar
a1sensei
I doubt anything you do with the air filter will make a difference you will feel in the seat of your pants. That said, the stock snorkel set up, especially if you have a dual snorkel, can draw cooler, denser (i.e. more) air than an open element under a hot hood.
God bless, Sensei
Old Jul 27, 2009 | 09:25 AM
Dantana's Avatar
Dantana
I bet you wouldn't note a seat of the pants performance gain even if you took the whole filter off...
Old Jul 27, 2009 | 12:30 PM
7T1vette's Avatar
7T1vette
I get a big 'kick' out of seeing the air cleaner snorkel opening(s) on some of the early '60s Chevy engines...even Corvettes, like the '64 with the double snorkel pipes having less than golf-ball sized openings. Obviously, the design Engineers felt those were adequate to supply air to the small V8 engine; so, needing a filter with lots of surface area is nice but not required.
Old Jul 27, 2009 | 02:48 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
IMHO, K&N air cleaners and similar do not filter out the smaller particles that will still damage an engine over time - especially if you live in a dusty climate.
I bet if you put the numbers to it, dollars / HP increase, the ratio would be one of the worst in terms of cost effective modifications (notice I didn't call it an upgrade)
Old Jul 27, 2009 | 03:12 PM
baxsom's Avatar
baxsom
i get a big kick out of these posts on how if it was good enough to be oem it must be the best.
seems to me its like trying to breathe out of a straw
but admittingly, i dont know anything.
Old Jul 27, 2009 | 04:10 PM
7T1vette's Avatar
7T1vette
I will agree that those air cleaners looked pretty odd. But, I don't know of anyone who had an operational problem with them limiting air to the engine. My point was not that GM can't do anything wrong [anyone who has been on this Forum and read my posts knows that's not the case]. My point was that an air cleaner with that small of an inlet area, apparently, works just fine....so spending $100 for a chrome tube with a big-a$$ air filter head makes absolutely no sense--from a functional point of view. Of course, they look ; and that's worth.....hmmmm
Old Jul 27, 2009 | 06:23 PM
terry82's Avatar
terry82
the filters will not add any hp but the stickers if placed correctly will add 20 -25 :
Old Jul 27, 2009 | 09:36 PM
7T1vette's Avatar
7T1vette
Old Jul 27, 2009 | 10:32 PM
mint79's Avatar
mint79
I don't know guys, my other car, 1973 duster 340, with the factory single snorkel[remember it is a 73] is o-k performance wise. With a aftermarket air cleaner[no vacuum doors] i know i have more h.p.you can feel the difference. only use the factory assembly for shows.
To Air filter power
