78 Turn signal switch replacement
Old Jul 27, 2009 | 09:24 AM
78 Vette Man-Craig's Avatar
78 Vette Man-Craig
1st Gear
Default 78 Turn signal switch replacement
Can anyone provide personal experience advice ...or refer me to an article on replacing the turn signal switch (tilt and tele.). I have been having continuing problems with turn signals not flashing-horn not working and feel it is the switch, or upper wiring harness problem. The switch looks like it will take major dissasembly to be able to replace.
Last time I worked on a "project" like this for almost two days...I went on line and in 15 minutes had 3 remedies to the problem I was experiencing ..and used them to fix the problem in 1/2 hour!
I also have a back up light issue. I reset the neutral switch at the manual trans...and the first time I use the back up lights, driving the car, the switch remains "closed" and lights stay on. I don't think the switch is bad....it works up on the lift perfectly....strange.
Old Jul 27, 2009 | 03:02 PM
Jim Shea's Avatar
Jim Shea
If you can obtain a turn signal switch from the 1970s early 80s era, I suggest the following. Go under the dash and disconnect the steering column wires from the vehicle harness at the "harmonica connection." Now hook your spare switch into the vehicle harness. Does the spare switch fix the problem?
The reason I suggest a spare switch is that a lot of suppliers may not allow you to return a purchased switch if it is removed from its original packaging. This will allow you to determine if the problem is the switch itself and whether or not you should spend the time and effort purchasing a new one.
The following turn signal switches are available from GM dealers: GM #1997984 or GM #1997988. Either switch will work. Purchase whichever is available and/or cheaper. You will find that the ..7984 switch has some extra wires for cornering lights. You don't have cornering lights but the switch should snap right into your vehicle harness with the the cornering light wires just not connecting to anything. Other Corvette suppliers have switches available as well.
If you need to replace the switch, I have complete instructions.
Go to: www.corvettefaq.com
Click on: Jim Shea's Steering Papers
Click on: Corvette Steering Papers
Scroll down to the Tilt & Telescoping 69-82 Disassembly & Repair Section
Download: Disassembly & Repair Papers #1 & #2
Download: Disassembly & Repair Pics #1 & #3
Note that the papers are available in Microsoft Word.doc and pdf formats
Further assistance is only a computor click away.
Jim
