When removing old mirror found one of the machine screws heads broke off and most of the threads still in car mount.
Suggestions on how to remove screw?
Can it be accessed if I remove the inner door panel.
Hi 70C3,
Because of the shape of the inner door frame in the area of the mirror mount there's no access to the back side of the screws even with the door trim panel off.
This sounds like a fix using a drill and a tap. Good Luck!
Regards,
Alan
