ive had problems with my new fuel pump not priming up, Ive worked out that there is a problem somewhere in my old steel line or maybe the pick tube in the fuel tank
I think the easiest solution is to replace the old fuel line with a braided fuel hose, then I thought I could drill a hole and weld a suitable fitting to the bottom of the fuel tank and fit new braided -10an hose to the fuel tank fitting
is there any problems with having a fitting at the bottom of the fuel tank, instead of a fuel pick up tube?
