69 Tilt column conversion
Old Jul 29, 2009 | 02:12 PM
TJP440's Avatar
TJP440
Default 69 Tilt column conversion
Would like to add a tilt telescoping column to my newly purchased 69.
What years are correct and will fit without modification???
Anything to be aware of??? I'm assuming it's a straight swap??
Tim
Old Jul 29, 2009 | 02:23 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Any column from '69-'75 will be direct fit.
kaiserbud's Avatar
kaiserbud
....btw - is that guy 'pink... ? (username?) still around that specialized in tilt column rebuilds?
Old Jul 29, 2009 | 03:12 PM
TJP440's Avatar
TJP440
Thank You
Old Jul 29, 2009 | 08:21 PM
oldboat's Avatar
oldboat
i did this in my '69. it was a very simple swap. the only thing that takes any time is switching the lock cylinder so you can use the same key.
To 69 Tilt column conversion
