To be sure, you should check the ratio by counting the turns of the driveshaft. Jack up the back end of your Vette so that the rear wheels can turn. Use a couple of extra jacks to make sure it's secure. Then put a chalk mark at the 6:00 position on the inside of one of the tires. Also put a chalk mark on the bottom of the driveshaft yoke. Then count the number of turns of the driveshaft that equals exactly one turn of the tire. That's your ratio. For example; 3-1/3 turns of the driveshaft to 1-turn of the wheels will be a 3.36 gear ratio.
If you want to really get accurate, then count driveshaft turns until the wheel turns 10 times, then divide your drive shaft number of turns by 10 and you'll have your ratio.
Thanks guys, I scraped the paint off & can hardly read it. It appears to be AW which would be 308 heavy duty posi. I bought the car as a project so I don't know alot about it. It came with a 396 Camaro engine & an M-21 Tranny. It has a BB hood & I'm almost sure it was originally a 427 car. I've since put a 2004R tranny in it. Do you think 308 gears will fly ?
I just stuck a 3.08 into my 77 that has a 200-4R trans. The 3.55 was howling on the coast (that prompted the change since I had the 3.08) Works just fine IMHO.
