Adding factory style A/C
Little bit off your question, sorry. I haven't seen any threads about someone installing a factory system other than the threads about one of the world's ugliest Corvette repair jobs- replacing the heater core/ Ranks right there with replacing trailing arms I think.
I think your best bet would be to find someone that's stripped all the factory stuff out of their car and went with no air/heat or installed aftermarket. Under the dash, there's a vacuum harness, ducts, cables and the control head- yours will be a little different from a no air car.
It can be done- may require some cutting/trimming of the hole in the firewall, and check your core support- the A/C lines run thru it on the right side, there should be a formed cutout in both the core suport and the inner fender just forward and above the right upper control arm where the condenser lines run. If it's not there, you'll need to cut/drill the core support too.
Not that it is much help with how to retro-fit the non-AC vehicle with OE style AC. I did find a lot of good replacement AC parts for my 72 when I was fixing the AC here.
http://tinyurl.com/n9gmwf
This site did not have everything I needed to complete my repair job but the parts they did have saved me a lot of money.
Hope this helps.
Ganey- you're correct recirc only, no outside air connection.
One of the big catalog companies sells a "factory looking AC" kit that's not quite factory - but uses the factory controls etc. I think it was $1200 and it comes with instructions that presume a "one time only" owner is going to do the install.
-W
I agree that the factory installation would be a BIG and expensive job. I've noticed that the A/C option in the 71 AIM is 38 pages long. The electrical harness changes alone are mind numbing.
I think Clam's suggestion of a factory looking system is the way to go.
Regards,
Alan
-W
Take a big heap of advice from the idiot that installed factory air on a 70 LT-1 Conv!
Really. . . And I mean really think this over! Then walk away!
Yes, you read correctly and I still own this car!
I did it, regret it and will remove it! There are some of you forum guys out there that are local and viewed this car and while it looks all AC’d up! I admit it, I’m the idiot. . . I’m a moron . . . why . . . because now I get to take all this off the car before I can finish it! This was by far my biggest mistake ever made on a Corvette!
I purchased this car in the late 1980’s and the car was not on the road for over 12 years before I purchased it. Some of you that viewed the CD or file on the windshield frame will recognize this yellow car as the 77k mile car used for this file. The car has not hit the road since 1977.
I have pictures . . . yes real Kodak pictures from 1992 when I got this bone headed idea. I can scan to show you what I did, but in a nut shell here I go.
You must remove the front end from the car to do a factory style conversion. You don’t have a choice if doing it factory! On a non air car there are two vents open on the driver side of the car, both were covered with a panel (number 4 and 5 in the picture colored blue) when the car was to have factory AC.
On the passenger side of the car you’ll find a special vent for AC cars that included a skeleton frame (number 1 in the picture and colored gray) that supported the abs plastic door and vacuum pod. This skeleton can not be installed with the front end on the car so you must remove it, fiberglass this in place and then re-install the front end.
Ok, next problem. You will need to remove the old heater box. Once you do this you will see the firewall pad and notice there is a perforation around the pad. This perforation was for installing the AC box on the car and is also the outline for the hole you’ll need to cut to install this new box. Yes, the box is larger and you will need to remove about 1” of fiberglass material. See picture below for details on how to cut this out.
Next the reinforcement dash issue. You’ll need to round up some factory AC support rods for the dash.
Next you’ll need to figure the wiring out. The AC control harness was different from that of the non a/c cars.
While it may look simple you’ll have to modify the car in such a way that a normal person can not person can not reverse . . .
Other things that will need to be changed: Add condenser and brackets to the core support, change the heater control unit, change the shift plate, obtain all the AC ducts for the car and so on.
Ok. . . I’m done for now! Save your self some real trouble, either buy an ad on kit and install it, or look for a car with AC.
Anyone want to let me have it I understand! Anyone wants hands on lessons on how to reverse this. . . .Call my office and get directions. I’ll buy the beer! Thank god I saved everything I removed!
Willcox
You should have offered to SELL him all that crap after you remove it - complete with installation instructions. Unethical? Hell no - he WANTS factory AC acording to the 1st post. So give it to him.
-W
Was it a tuff job? Yep. But there were no aftermarket kits back then other than the hang-on units.
