car won't start
Old Jul 30, 2009 | 09:45 AM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
Default car won't start
1968 vette : I tried to start yesterday and battery was dead I got a new battery and seemed to cure the problem. I went out this morning to start it and nothing not a click anything, then I started to get smoke from the dash region I beleive. Not a heavy billowing smoke just a quick smoke and gone. It smelt like it might have been electrical. I have started removing the dash to see if I can find the culperat, Anyone have an idea of what the problem might be?
Old Jul 30, 2009 | 10:20 AM
Former Vendor
alrighty, I pulled the ignition switch and found that the wire that runs to the solenoid (purpe wire) looks like it grounded out some where some how and has bare wires showing. Do i need to replace the solenoid after checking the wire?
Old Jul 30, 2009 | 10:55 AM
GruntyPants's Avatar
GruntyPants
No, the solenoid should be unaffected by the grounding. Carefully check the rest of the wires, and give it a try and see what you get.
Old Jul 30, 2009 | 11:07 AM
Former Vendor
got lazy and decided to call my mechanic to do it. I don't know a great deal about electronics and don't want to screw anything up.
Old Jul 30, 2009 | 11:24 AM
73StreetRace's Avatar
73StreetRace
Good choice ! Not to be lazy, but to call your mechanic
Old Jul 30, 2009 | 12:08 PM
Dantana's Avatar
Dantana
i wrestle with the same thing every time I have an electrical problem...
Old Jul 30, 2009 | 12:43 PM
Former Vendor
I looked around some more at the wiring and really couldn't find anything melted, the only thing I found was the one wire off of the ignition switch and its not burnt just the plastic has come back but no burn marks on it.
Old Jul 31, 2009 | 10:29 AM
Ward72's Avatar
Ward72
I saw this on the sports Car Market after reading your trend..... New Product on the market.
http://www.youtube.com/watch?v=cY1YndLmbXQ
Hopefully you got her running.
Old Aug 1, 2009 | 08:31 AM
Former Vendor
My mechanic came over and told me that the reason for the smoke was my engine wasn't grounded and the ignition was looking for ground. He grounded the motor to the frame and car starts better now than it ever did. Also found out my alternator was only putting out 12.5 volts so got a new one. This should cut down on the taxing of the engine and allow for more power and less heat.
To car won't start
