popping in carb.....
Here is what I got. 81 350/350.. had the computer control but yarded all that and the smog. bolt on HP (header, edelbrock intake, and 1405 carb) HEI distrib, ect....
problem is that at high cruise mode- WOT it starts popping in the carb, almost a backfire. does it when she is at temp but not when you first take off. only does it under load.
fuel pressure is 5-6 psi at the carb. seems to run better with the timing way advanced 30*(I know this is bad too) choke is opening, idles fine. checked for vac leaks, valves are adjusted correct,
Here is what I was thinking
A) carb to lean? start playing with the needles and jets.
B) the stock computer cam is not maching to the intake and carb?
C) or I just dont know what Im doing
What do you guys think?
Having to run 30* initial advance might make me suspect the timing chain/gears might be headed south.
If it is a single pop then its likely timing or mixture.
If it is is a series of pops that caries on until you back off the of the throttle, then I believe midyear is correct.
