I had this happen to me, the hardest part will be getting the hood open. The cable install is a breeze. I lucked out and had enough play in the hood that I could wiggle it back and forth and it popped up. If that hadnt worked there is a release lever that the cable hooks to on the drivers side. If you can get to that and push or pull on it then you will be set. Im not familiar with your year so I'm not exactly sure how to get to it.
Yes, it just slides in. Same thing happeded to me. I would probably put some kind of lube or graphite in the tube & on the cable before you install it. I didn't and I have to push back in manually after I release. Either a weak spring or lubrication issue. It will take all of 5 min. to install. I guess I should redo mine.
FYI . . . the cable comes molded on the handle, so you actually are replacing both. The dash mount is separate unless you buy.
