Hi!
Had the same problem. If you disassemble the rear compartment storage frame you can slide with your hands under the carpet and so you can locate it. Take nails in the holes and press the carpet over the nails...then you should have it :-)
Yep. Get a big needle and start pokin'. The AIM will show the approximate locations for the holes. Once you find them, you can use a pencil-type soldering iron to put some small holes in the carpet at the right place. Just don't breathe the fumes and work quickly to minimize the amount of melting. (Keep water/fire extinguisher handy...you won't need it, but it is peace-of-mind.)
Who has that loop that mounts at the rear of the console? I may be blind but I haven't been able to find it. The 77 has the straps mounted from the rear, but the loop for the front is AWOL.
