Big Block springs
Old Jul 30, 2009 | 06:39 PM
forvicjr's Avatar
forvicjr
Default Big Block springs
Should i change front springs, rebuilding front end with current small block,planing on having 496 finished by end of winter will BB springs be to stiff to use untill swap?
Old Jul 30, 2009 | 07:38 PM
Clams Canino's Avatar
Clams Canino
I'd put the new springs in now to break them in, and to avoid "rework".
-W
Old Jul 30, 2009 | 07:40 PM
TimAT's Avatar
TimAT
The front end might set a little bit high. Unless you really truly enjoy front end work and springs, put them in while it's apart. Be happy.
Old Jul 30, 2009 | 07:42 PM
forvicjr's Avatar
forvicjr
Default springs
thanks for responding, just didnt want the car to be nose high with the small block. think this will be an issue?
Old Jul 30, 2009 | 08:01 PM
TimAT's Avatar
TimAT
Maybe a little bit high. BB springs are physically shorter as I recall, so it might offset. Odds are it won't look like a '50 Chevy Coupe or an old ****** with a straight axle under it.
Old Jul 30, 2009 | 08:09 PM
Clams Canino
If you're using the long bolts in the rear to lower it at all... just crank them up a little to compensate if you feel the front is high.
-W
Old Jul 30, 2009 | 08:51 PM
jfleye's Avatar
jfleye
Default springs
If memory serves, mine are 550-1inch short on my 454. I have 235s on the front and 255s on the rear and it seems to work out just right.
Old Jul 30, 2009 | 09:06 PM
72LS1Vette's Avatar
72LS1Vette
The VB&P 550# springs are supposed to lower the front end 1". I can't be sure on my car because it hasn't been driven yet and the engine is lighter than the stock 350. The car is sitting ~stock ride height now. If you are putting in an iron block engine they should work out nicely. BTW, from what I have read the #550 springs are considered 'medium' stiffness so you should be OK with the ride quality until you put in the big block.
Rick B.
Old Jul 30, 2009 | 10:17 PM
Richard454's Avatar
Richard454
Small block springs might work just fine-IF you are going w/ aluminum heads/intake on the 496- It'll be close to the same weight as a small block w/ iron heads.
Richard
Old Jul 31, 2009 | 01:25 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
From what info I've gathered an L82 SB weighs in at ~525#, while an alum head/intake BB is at ~620#. That's only about 50# extra load per side, so you're not looking at a great deal of difference. Yes, 550# front springs are mediums (860's here), and many a performance minded enthusiasts finds them more than acceptable with a SB. ...tho IMCO a few CF'ers do seem to have some rather soft backsides.
TSW
To Big Block springs
