Buy this engine?
Old Feb 15, 2002 | 01:30 PM
ruskus's Avatar
ruskus
Default Buy this engine?
The current engine in my 1969 427 is a 1973 454 with a spun bearing. I have been debating rebuilding or replacing. This seems like a cost effective solution. Any thoughts on the engine below? Anything to watch out for? I plan on using my intake manifold, original to the car and purchasing a new carb and ignition system. Thanks. Russ
427 Big Block Chevy Cresco High Perf. 427 BBC
Item # 1804592939
Item located in: Parts & Accessories:p:arts:Car & Truck:Engines & Components
Starts at $2,855.00
Buy It Now for $2,900.00
This option disappears
once a bid is placed.
First bid $2,855.00
Quantity 1 # of bids 0 (bid history)
Time left 22 hours, 19 mins + Location Charlotte , N .C .
Country United States
Started Feb-11-02 07:46:19 PST (mail this auction to a friend)
Ends Feb-16-02 07:46:19 PST Watch this item
Featured Category Auction
Seller (Rating) alohadjc@carolina.rr.com (257)
427 CID Cresco Motorsports engine . Fresh , never fired , high performance build . Standard deck height 427 cubic inches of displacement . Heavy duty internals include a 427 forged steel crank , which has been crossdrilled and champhered , micropolished and has the journals radiused for strength . It is checked for runout and has been fitted with forged steel heavy duty rods with new ARP 200 , 000 psi bolts and new 427 Keith Black pistons that have been coated for extra performance and fitted with Sealed Power Chrome Moly rings . Designed for strong , reliable real world driving with a compression ratio at a very streetable / pump gas 9 . 5 to 1 . GM big block is freshly machined with a . 030 bore , examined and magnafluxed for cracks , checked for deck squareness , machined for precision clearances , new cam bearings and brass freeze plugs installed and Professionally Assembly by Cresco Motorsports in Charlotte , N .C . The 427 build is assembled with all rotating assembly bearings by Clevite , new Heavy Duty Melling oil pump and pickup , ( each engine ' s oil system is fully primed prior to shipment ) and a new chrome oil pan with chrome dipstick . We use the best breathing GM heads built for torque , large oval port heads , freshly built with all new parts and a stage II , three angle valve job , upgraded valve sizes to the 2 . 19 / 1 . 88 large valves and 113 cc combustion chamber . These are built for crisp throttle response . Cloyes TRUE Roller Timing Chain . The ideal big block cam for the balance between awsome " right now " power and driveability is a " no maintenance " hydraulic Crane Energizer # . 533 " cam , with 282 advertised duration and 1 . 70 ratio rocker arms with new hyd . lifters , pushrods and guideplates . Intake is an aluminum dual plane and a new water pump and harmonic balancer are included . Power rating for this ideal combination of carefully selected parts is between 425 and 450 horsepower and torque . Perfect match of parts for optimum real world needs . This 427 is built for those who require a fresh , reliable , streetable , big block Chevy built to last . Includes a 12 month conditional , unlimited mile warranty . Your engine arrives on a new engine stand inside a fully enclosed shipping crate . It travels fully insured to the terminal / dock in your area for pickup . We will split the cost of shipping with you and guarantee your portion not to exceed $ 250 . within the Continental USA . This is only a 5 day auction with funds due to us within 5 days from the end of auction in the form of a money order or cashiers check ONLY please . Thanks for looking and good luck bidding !
Old Feb 15, 2002 | 02:36 PM
flood's Avatar
flood
Default Re: Buy this engine? (ruskus)
You have to be real careful on ebay.
That sounds really cheap too. :confused:
Old Feb 15, 2002 | 03:06 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Buy this engine? (flood)
Sounds too cheap. If it's too cheap to be true....
Anyway you can check the motor out in person before buying it????
Old Feb 15, 2002 | 03:10 PM
ruskus's Avatar
ruskus
Default Re: Buy this engine? (Mike69)
I hear what you are saying. I am trying to contact prior buyers from this guy on similar engines to get some feedback.
Old Feb 15, 2002 | 03:26 PM
Maurice's Avatar
Maurice
Cresco Motorsports? I did a search on google and didn't come up with anything. I am not familiar with any of the engine builders though. The guys feedback is near perfect and the engine does have "a 12 month conditional , unlimited mile warranty ". I would find out what "conditional" meant though. "Power rating for this ideal combination of carefully selected parts is between 425 and 450 horsepower and torque" - sounds like it would be an improvement over the 73's engine. Good luck!
Old Feb 15, 2002 | 05:55 PM
The Dude's Avatar
The Dude
I don't know--you pays yer money and you takes yer chances.
It sounds like it was assembled using the "right" parts. But the only way a buyer will know for sure is to disassemble the engine to check that you got what you paid for. "Clevite bearings," for example. How are you going to know that you got those bearings unless you strip the engine?
I, too, would like to know what a "conditional" guarantee consists of.
To Buy this engine?
