Engine diesels
Old Jul 31, 2009 | 10:42 AM
76yellow's Avatar
76yellow
Default Engine diesels
My 68 427 4spd diesels after shutting it off. What could be the causes & or remedies ? Timing maybe ?
Old Jul 31, 2009 | 10:57 AM
Donald #31176's Avatar
Donald #31176
Over advanced initial timing and too high idle speed are the most common causes. Reducing the advance or idle speed might be helpful. If you wish not to fool with those settings you could also when shutting down the engine leave the trans in gear and release the clutch to where it barely engages and turn off the ignition.
Old Jul 31, 2009 | 11:04 AM
63Nova's Avatar
63Nova
Old Jul 31, 2009 | 11:11 AM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Usually caused by retarded timing and the throttle blades being opened up too far to compensate for the retarded timing. Do you have the vacuum advance hooked up to manifold vacuum?
Old Jul 31, 2009 | 11:15 AM
DRIVESHAFT's Avatar
DRIVESHAFT
Yep
Old Jul 31, 2009 | 12:17 PM
76yellow's Avatar
76yellow
No, the advance is hooked up on an upper tube on the front of the carb. Its a Qjet
Old Jul 31, 2009 | 12:20 PM
76yellow's Avatar
76yellow
I just set the timing at 12 with the vac advance unhooked & it still does it.
Old Jul 31, 2009 | 12:33 PM
TimAT's Avatar
TimAT
Idle speed? I gave up on REd and put a lightweight flywheel in. Not only does it spin up quicker, when you turn the key off, it's done. Dead stop right now.
Old Jul 31, 2009 | 02:02 PM
69427's Avatar
69427
I'm not a Q-jet expert. Is that tube manifold vacuum or ported vacuum?
Old Jul 31, 2009 | 02:15 PM
mattt0305's Avatar
mattt0305
3rd Gear
there is a rubber diaphragm in the vacuum advance that can go bad. The vacuum advance wont work and cause a vacuum leak, mine did the same thing and dieseled. Pull a vac on it with a hand pump with the cap off and see.
Old Jul 31, 2009 | 03:40 PM
76yellow's Avatar
76yellow
Thanks guys....The tube in the front of the carb is high up so I'm guessing its ported. I'll check the vac advance tommorow to see if its working.
Old Jul 31, 2009 | 04:00 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
12 degrees initial with the vacuum advance disconnected and plugged sounds like a lot to me for a big block. Spec on mine is like 6 degrees at 800 rpm IIRC. I know small blocks commonly run at 12 initial, but stock big blocks are usually less.
Old Jul 31, 2009 | 10:01 PM
76yellow's Avatar
76yellow
Thanks PK, I'll change it tomorrow. My tach does'nt work do to no cable right now but I can lower the idle a little more.
Old Jul 31, 2009 | 11:09 PM
TimAT's Avatar
TimAT
Sorry, I had to. My low idle is right at 1000 RPM.
Anyway, high idle is a real distinct cause of run-on, dieseling or whatever yu want to call it. It can be caused by adjustment, vacuum leak(s), timing incorrect just for a start. Another thing can be carbon in the cylinders- makes little hot spots that ignite the fuel air mix. And the gas we all get today is not what it used to be.
Old Aug 1, 2009 | 12:04 AM
CCrane65's Avatar
CCrane65
Guys, that's why GM put idle stop solenoids on these cars. To ensure the throttle blades are completely shut when you turn the car off.
My bb had the same problem before I purchased an idle stop solenoid and set the idle speed up correctly.
I have not had any dieseling in the three years since.
cc
To Engine diesels
