One Eye Open, 68 Headlight Doors
Old Aug 4, 2009 | 11:30 PM
Makoman 68's Avatar
Makoman 68
2nd Gear
Default One Eye Open, 68 Headlight Doors
I have a 1968 coupe that has worn out headlight accuators. I've been able to turn the headlights on and raise the doors by hand. The lights and doors would always turn off and close when pushing in the light switch. Well this past weekend the right door closed but the left stayed open and won't budge. The asemblies are in good shape.. any suggestions how to get the door to close without breaking something!!! Thanks
Old Aug 5, 2009 | 12:24 AM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
You can manually close the light by lying on your back in front of the car and reaching above the headlight linkage and pulling down on one of the assembly linkage rods. This will collapse the assembly and allow the light to close.
Old Aug 5, 2009 | 05:04 PM
Alan 71's Avatar
Alan 71
Hi M68,
I believe the piece of the headlight mechanism you need to pull on to get the door to release and started on the way down is shaped like a 'knee' and is simply called 'link' in the AIM. You do reach up from below, as H suggested, to get to it.
It sounds like your actuators need to have new seals put in them. You can do this job and the venders sell the seals.
Regards,
Alan
Old Aug 5, 2009 | 09:37 PM
colin75's Avatar
colin75
check out this recent thread it really works. it did for me
http://forums.corvetteforum.com/c3-t...=headlight+fix
Old Aug 10, 2009 | 10:08 PM
Makoman 68's Avatar
Makoman 68
2nd Gear
Default Thanks!
Hey thanks for the suggestions and the link. I went out ,crawled under the car and nudged the nuckle area and the light mechanism closed right up! This is now my favorite new websight!!!!!!!!!
To One Eye Open, 68 Headlight Doors
