Engine Experts, need input: LT1 Heads?
Old Aug 5, 2009 | 10:06 AM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
Default Engine Experts, need input: LT1 Heads?
Does this deal look kosher? I'd like to get some expert feedback before I consider this...
http://tucson.craigslist.org/pts/1297637027.html
Old Aug 5, 2009 | 10:11 AM
DRIVESHAFT's Avatar
DRIVESHAFT
You might be better off asking this in the C4 forum since theses are for the 94-97 LT1.
Old Aug 5, 2009 | 10:12 AM
billla's Avatar
billla
St. Jude Donor '14
Not sure what you're asking. These are GEN II heads that won't fit on a GEN I SBC as the GEN II's are reverse-flow cooling.
If you're building a carb-d GEN II for your C3, then the price on these is too high IMHO and the machine work sounds iffy. Bigger valves won't help too-small ports, and there's no reason to deck these heads (?) Decently ported and overhauled LT1 heads are available for around that price or a bit more - and there are better heads in the aftermarket for around $1400 or so.
RobbSalzmann
St. Jude Donor '12
Doh! Thank you.
Old Aug 5, 2009 | 10:15 AM
RobbSalzmann
St. Jude Donor '12
That's exactly what I needed to hear. I was a bit suspicious about the decking too (like, were they warped from overheating?)
Case closed, thanks everyone!
To Engine Experts, need input: LT1 Heads?
