Has anyone heard or have first hand knowledge that these blade type side terminal battery disconnect switches being unsafe or problematic in any way? Please advise.
I have one of those on my battery. They are about as simple as you can get mechanically. If you use it on the ground terminal there shouldn't be any problems. If you use it on the + terminal you have to be careful that there isn't any grounded surface nearby due to the large exposed metal area.
Rick B.
Hmm, didn't know that. I have one connected to the positive terminal. May have to look at changing it. They can be a little troublesome when trying to open or close the blade due to the tight quarters in the battery box, but I use mine all the time. Definitely better than the screw-type disconnect.
Rick B.
I believe the manufactures instructions say to install on the neg terminal only.
I have one on all of my collector cars. Have put them on pos terminal on my vettes on occasion. It seems to have better clearance and only has fiberglass to hit on the perimeter. Therefore no short outs. On my metal bodied cars I always put on neg terminal.
I put mine on the + side because I need a constant +12v source for the LS1 ECU memory and I needed to have the battery ground connected. I modified mine a bit by drilling out the threaded side of the switch cable mounts so that I had more mounting options.
I've worked at a couple of companies that built hot-pluggable circuit boards and the connectors were designed so that the ground always connected before the supply voltage to avoid arcing. I don't know if you get a spark when switching the negative battery terminal with the blade switch but I haven't seen any sparks from the positive side.
I'm just guessing here, but the recommendation to mount the switch on the negative terminal may be more for safety due to the large exposed contacts than for any other reason.
Yea man, I put the same thing on my 79 the day after I bought it.
BTW I disconnect each time I park in the garage.
I've had one on both my cars and they work great. In my opinion, they are better than the **** screw type as I've had one of those actually touch together when the battery cable relaxed.
Since they are in a non-metallic battery box, it's not likely that you'll have any problem. I went with the twist-type [threaded ****] just so it wouldn't have so much metal exposed.
As I recall, the NCRS gives extra points for having one of these types of disconnect switches on your battery.
cc
Yes, I'll get 4 extra NCRS points for a battery disconnect switch. If not for this, I'd just keep it stock as I have a Battery Tender, which works great, and only a couple of times a year do I really have to disconnect the battery. A 7mm ratchet works just fine for the occasional disconnect.
Anyway, thanks for all the great comments - as usual
I talked to a solid axle guy , original owner, looking for more accurately dated windows because his ORIGINAL windows weren't close enough for the judges. And now I hear that battery disconnects and fire prevention gets points?!?!?!
