Overheating
Old Aug 5, 2009 | 06:23 PM
TyCor's Avatar
TyCor
Default Overheating
This should be an easy one I think. 1977 vette, auto. If the radiator is pushing coolant into the overflow tank, what does this mean? while this was happening, the temp was increasing as well. what can cause this to happen?
Old Aug 5, 2009 | 07:32 PM
dannyman's Avatar
dannyman
Air in the coolant system! Have you been working on the cooling system lately?
Old Aug 5, 2009 | 07:33 PM
Mike Ward's Avatar
Mike Ward
Weak rad cap.
Old Aug 5, 2009 | 07:49 PM
speedreed8's Avatar
speedreed8
a leak, low on coolant
stuck thermostat
bad fan clutch
a million bugs , leaves, clogging the front of it.
blown head gasket.
lower radiator hose collapsing ( spring collapsed inside)
man i better stop, bringing back bad memories of when i first got our vette.
oh yea, worn out water pump.
Old Aug 5, 2009 | 08:15 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
How hot was it?
Old Aug 5, 2009 | 08:52 PM
randyredleg's Avatar
randyredleg
Is the radiator cap screwed on all the way?
Old Aug 5, 2009 | 09:17 PM
TyCor's Avatar
TyCor
Basically all of the radiator coolant was forced into the overflow tank and then the overflow tank was venting it overboard. I just finished draining/flushing the system...there was water left in the radiator when I tried to drain what was left. the cap was tight, all hoses look good. the water pump is working I think becuase when I flushed the radiator, I did it with the engine running and it was moving water through the stytem. I am suspect that the pump maybe going...is there anyway to tell? is this a hard thing to fix?
Old Aug 6, 2009 | 03:50 PM
GeorgeS's Avatar
GeorgeS
My 68 has a FULL mark on the radiator tank (passenger side) about 4 inches below the top. So "full" does not mean up to the cap!
Old Aug 7, 2009 | 12:56 AM
Mike Ward's Avatar
Mike Ward
The OP has a '77, very different cooling system than '68. All '73 and up Corvette rads are to be filled to the brim.
Old Aug 7, 2009 | 09:07 AM
dannyman's Avatar
dannyman
Sounds like a normal coolant system issue. You may have to drill a 1/8 inch hole in your thermostat to allow the trapped air to escape and allow the system to be properly re-filled. Still indicates to me that you have air in the system.
Old Aug 7, 2009 | 12:05 PM
Dantana's Avatar
Dantana
I'd drill 3...
Old Aug 7, 2009 | 12:23 PM
noonie's Avatar
noonie
Stewart pumps recommends 3 holes only if you plug the internal bypass cicuit, which they do in there better pumps.
Using the bypass, 1 hole is enough.
Most tstats come with a hole that is less than 1/32"
To Overheating
