Fan Clutch
Anyway, I changed it to a new one, and now the car sounds like a Cessna 152 when I rev it above 3000 rpm! I can definitely hear the fan roaring when I rev the motor. Is this normal? Can I change to a flatter pitch fan to quiet it down. Like I said, even with the worn clutch, the car ran very cool. Thanks, Fellas!
Temvette72
Temvette72
I have the same noise with mine. 74w/350. I think it just goes with being new. Only time will tell. glassman74
Never did figure out what made that new clutch sound so loud.
Temvette72
Temvette72
Temvette72
Here is some info on different clutches.
Non-Thermal Fan Clutch
• Low cost alternative for some standard thermal clutches.
• Always engaged, less fuel savings than a thermal clutch.
• Spins at about 30-60% of the water pump speed.
• Shorter life expectancy.
• Cannot replace a heavy-duty clutch.
• Identified by the smooth, steel faceplate, (without a thermal spring assembly), on the front.
Thermal Fan Clutch
• Varies the fan speed with temperature of the air behind the radiator.
• Engaged (high speed) operation provides maximum cooling.
• Disengaged (low speed) operation provides fuel savings and noise reduction.
• Greater life expectancy than a non-thermal clutch.
• Briefly engaged at cold start-up.
• Engages at about 170° radiator air temperature, (about 30° lower than coolant temperature).
Standard Duty Thermal
• Turns fan 60-70% of shaft speed when engaged.
• Disengage to 20-30% of the shaft speed
• Used with lighter pitch fans. (1-1/2” of pitch).
• Flat plate impeller design with 11.4 Sq. In. of working surface.
• Identified by a smooth steel faceplate & thermal spring assembly on the front side.
Heavy-Duty Thermal ….. Corvette AZ GM # 372502
• Turns the fan 80-90% of the shaft speed when engaged for increased cooling.
• Turns the fan 20-30% of the shaft speed when disengaged.
• Used with deeper pitch fans. (2 -1/2” of pitch).
• Land and groove design with 26.0 Sq. In. of working area allows higher operating RPM’s.
• Identified by finned aluminum faceplate and thermal spring on the front.
Severe Duty Thermal …..Corvette AX old-GM # 343721 new-GM # 88961768
• Turns the fan 80-90% of the shaft speed when engaged.
• Used with deeper pitch fans. (2 -1/2° of pitch).
• Land and groove design with 70 Sq. In. of working area.
• Larger working surface provides cooler running and longer life expectancy.
• Thicker body and deep finned faceplate dissipate more heat.
• Can be used in place of many heavy-duty clutches.
Here is a link to the full page.
http://www.haydenauto.com/Featured%2...s/Content.aspx
