1977 Trailing Arms
Old Aug 7, 2009 | 01:03 AM
ezrider01's Avatar
ezrider01
Default 1977 Trailing Arms
Hey out there...
Wanted to get some advice on an area I am currently working on my 1977 rebuild. I have been contemplating swapping out my OEM trailing arms and replacing them with some remanufactured off-set trailing arms. My goal is gain some space so that I can run some wider low profile tires on 7x16" wheels. But as I look closely at the wheel well and frame area...It doesn't seem clear to me that I would gain the advertise 2" additional space.
So before I dump a $grand$ on the parts…is there someone out there that can tell me if in fact I will or will NOT be able to run wider wheels? What was your experience on ride performance? If its all good, any recommendations for a supplier?
Thanks in advance…Ez.
Old Aug 7, 2009 | 06:36 AM
Gordonm's Avatar
Gordonm
The 16X7 wheel is not wider than a stock wheel. The stock wheel is a 15X8 inch wheel. The offsets are needed for 9 or 10 inch wide wheels in a 15 or 16 inch wheel. If you run a 17 or 18 inch wheel in a 9 or 10 inch width the stock arms will work with relocating the ebrake cable. The off set arms are a little stronger and are probably not going to be rusty like your stock arms also.
Old Aug 7, 2009 | 10:45 AM
ezrider01's Avatar
ezrider01
Gordonm...thanks for the reply and input. I hadn't realized I could run 17 or 18 inch wheels on the 77...a sure sign of my obvious ignorance. Okay, Assuming I go with the off-set arms, which configuration would you suggust I run to stay within the exterior body lines? 7x9, 18x10??? My goal is to have the low sleek with fat guns look...if that makes sense.
Thanks again for your inputs.
Old Aug 8, 2009 | 05:31 AM
onaqwst's Avatar
onaqwst
the largest wheel for a 77 is a 20x9 with 0offset/4.5" backspacing with a 45 series tire.....i have that setup and no rubbing and using stock suspension
Old Aug 19, 2009 | 12:54 AM
ezrider01's Avatar
ezrider01
so are you running 20x9s all around??? what do you mean with "4.5" backspacing"? I like the look on your ride...exactly what I am after. tks.
Old Aug 19, 2009 | 09:54 PM
7t3shark's Avatar
7t3shark
Backspacing is the distance from the wheel mounting surface to the inside lip of the bead mounting surface.
Offset is the distance between the wheel centerline and the wheel mounting surface.
Old Aug 19, 2009 | 10:18 PM
doctorgene's Avatar
doctorgene
Yes Sir; Why don't you get hold of Van Steel @ www.vansteel.com These people are the Mfg. of the finest offset trailing arms made. I think that guy has tried every thing that you can do with them. Have a great one. Gene
Old Dec 20, 2010 | 12:39 PM
ezrider01's Avatar
ezrider01
Default Still On the Wheel Issue - 1977 App
Here I am a year later and still working the wheel issue. Its okay my ride is still a work in progress as well i just may have come up on a good deal for some wheels...I have dropped the $grand$ plus to replace my trailing arms however...so there has been some progress...lol.
So can anyone help me and say if I can run 18" X 8.5" wheels with 245/40ZR18 88Y tires for the front, and the rear with 19" X 10" wheels with 285/35ZR19 90Y tires? Without rubbing that is. Recall that I am also running off-set trailing arms now as well, the rest is replaced new stock suspension.
Old Dec 22, 2010 | 11:34 AM
ezrider01's Avatar
ezrider01
So you can say if I can run 18" X 8.5" wheels with 245/40ZR18 88Y tires for the front, and the rear with 19" X 10" wheels with 285/35ZR19 90Y tires without rubbing? I am also running off-set trailing arms as well, the rest is stock suspension.
To 1977 Trailing Arms
