1968 327 replacement & removal
just remove the 4 trans. bolts and yank it
use a floor jack under the trans. for installation
If you have typical cherrypicker hoist ... it'll have to be sideways, don't think it matters drive or pass side. First, I put C3 on 6 jackstands.
suggest go ahead & pull old distributor out BEFORE you pull old motor ... & install new motor in BEFORE it gets a dist. Especially if you do this without a helper.
With the new engine, you will need to mount the clutch and bellhousing. Are you buying a new clutch? Has the flyweel on the rebuilt engine been resurfaced? You really should check the center of the bellhousing on the rebuilt engine with a dial indicator. Offset pins are available if any adjustments are required. It is much easier to insert the tranny into the clutch/TOB and torque to the bellhousing when they are all out of the car.
New flywheel, pretty much everything is new from summit racing. Clutch on the current engine only has about 200 miles before the headgasket and rings went. Was thinking of reusing unless someone has reason I should not.
Sounds like either way I have to disconnect everything from tranny anyways so might as well pull it all.
Thanks for all the detailed pictures here. You mentioned and engine leveler...don't believe I have one of those. How would I use it and when?
I have a helper, but is clueless to what I am attempting to do, so should be interesting.
You can see it in the picture. Turning the threaded rod changes the incline of the engine when coming out and going back in. Just makes the job easier and lessens the chance of damaging anything. Really helps when you only have an extra set of hands.
