Torque converter
Old Aug 7, 2009 | 10:19 AM
Sho'nuff's Avatar
Sho'nuff
Default Torque converter
Guys,
Looking at an engine CT383ET1 from Year One. The cam specs are 234/234 dur.@50 with 540-540 lift. Wondering if i can get by with a stock converter or have to go with a 2000 stall??
Thanks!
Old Aug 7, 2009 | 10:26 AM
BKbroiler's Avatar
BKbroiler
Your car will be an absolute dog with a stock converter in it.
Old Aug 7, 2009 | 11:08 AM
Sho'nuff's Avatar
Sho'nuff
So will 2000 be enough?
Old Aug 7, 2009 | 11:21 AM
smon's Avatar
smon
While the engine is out, I would go ahead and replace. I went with a b&m 2500 stall and it seems to be just about right since my car is street driven.
Sean
Old Aug 7, 2009 | 12:01 PM
Sho'nuff's Avatar
Sho'nuff
Kool, 2500 isnt bad. I'd like to hit the strip once or twice just to see what it will do. Just street cruising other than that.
Old Aug 7, 2009 | 04:07 PM
7T1vette's Avatar
7T1vette
If you will be using the car for normal driving most of the time, installing a 2500 rpm (or higher) stall speed converter will really affect driveability and fuel economy. Normal stall speed for a stock C3 would be in the 1600-1800 rpm range. A good middle ground for driving and performance would be a 2000 rpm converter. If your engine doesn't come alive until 3000 rpm or more, performance will suffer without installing a 2500-2800 rpm converter, however. You will have to decide what you want out of this combination. It is important that you contact the converter manufacturer (tech support) and order a unit that will have the stall speed required for the engine you have built. The stall speed of any convertor will differ depending on the torque/HP capabilities of the engine. You can't just buy any old 2000 rpm stall converter [intended for a stock engine] and expect it to perform properly with a beefed-up powerplant.
Old Aug 7, 2009 | 04:33 PM
BKbroiler's Avatar
BKbroiler
Another factor in selecting the right stall speed is rear axle ratio. What gear is in there now?
Old Aug 7, 2009 | 04:49 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Thats a pretty healthy cam. I really doubt a 2000 stall speed would make you happy. I think you are going to need 2500 minimum.
Old Aug 8, 2009 | 11:01 AM
OldCorvetteKid's Avatar
OldCorvetteKid
I just went thru this myself. IMHO...from the specs of that cam, I would think peak torque would be about 4500 RPM,s. Your converter should be no more than 1500 RPM's below peak torque RPM...a 3000 stall converter should be close to optimum depending on rear-end gearing ofcourse. From my experience a 2000 stall acts way too much like a stock one, and I didn't that notice much of a change in performance and was very dissapointed. Also changing to a 10" (instead of the stock 12") makes a world of difference, because of the weight difference.
Old Aug 8, 2009 | 11:36 AM
Sho'nuff's Avatar
Sho'nuff
running 3.08's with 25.5 in. tires
Old Aug 9, 2009 | 01:38 AM
OzzyTom's Avatar
OzzyTom
That cam would much rather see 3.55 or 3.73 rear end.
3.08 diff gears will make for sluggish takeoffs.... unless you can get rpm up at launch.
3000 rpm minimum stall is what I'd be putting in... especially with that 3.08 diff.
Old Aug 9, 2009 | 02:06 AM
gingerbreadman1977's Avatar
gingerbreadman1977
i say a good trade off is 355 gears and 2500 stall. once you go to a 3000 stall price jumps up significantly and around town you will hear that stall working overtime ( even though i have a 3000 but had to go that high to suit my cam). you would not want to be cruising on the hiway at 2500 rpm and have a 3000 stall or you will be cooking your transmission fluid no end. you have your cam selected so you will need to choose what rear gears you stick with then choose a stall thats slightly lower then your cruise rpm.
Old Aug 9, 2009 | 08:05 AM
Sho'nuff's Avatar
Sho'nuff
Was hoping the shorter tires would kinda make up for the 3.08's.
Old Aug 9, 2009 | 04:08 PM
BKbroiler's Avatar
BKbroiler
Doing a little math shows that there is an 8% difference in circumference between a 25.5 inch diameter tire and a 26.5 inch tire. The difference between 3.08 gears and 3.55 gears is 15%, so your short tires help a little but really its like using the standard tire with a 3.30 or so gear. Not good for standing start acceleration.
You mention you might make a few passes on a drag strip. If there is any chance you will make a lot of passes (it can be a little addictive), go with at least 2,500 stall converter and 3.55 gears. That combination is not bad for a non daily driver street car. I have a 3,000 stall and 3.73 gears and its tolerable.
To Torque converter
