Q-jet secondary
basically the cam/hangar determine how fast and far the rods open the jets
the rods determine how much the jets can flow.
these adjustments tune the secondary for best power
things like weight of car and gearing and vacuum from cam.
God bless, Sensei
P.S. Hangers don't matter. You can bend any hanger to get what you need.
No 10, should be 2 letters.
Must have been the 10 drinks I had and not wearing my glasses!
See, another lesson learned, but it was fun..............
Thanks again
try: www.73-87.com/7387garage/drivetrain/damon.htm for how to tune the secondaries and what rods are the best.
The tuning in above link is for 350s.
Not for high power 383 & BB.
1. Don't take out your secondary air valve shaft and replace it with one from a junk yard!
You don't need to do this and you could cause serious problems if you don't know what you are doing. I have been doing performance Quadrajet builds for racers/ hot rodders for years and have never found one that needed this to get full air valve opening.2. Don't waste money on secondary rod hangers.
The only difference in one hanger to another is how high or low the holes on the hanger's arms are. The arms are easily bent to put the holes at the desired height.God bless, Sensei
1) Removing the little screws that hold the air-valves (and throttle blades) is tricky; not a '2 on a scale of 1 to 10 on the difficulty scale'. The ends of the screws are pressed and fattened to limit thier backing out and falling into the intake. It takes a careful touch to remove them without hogging out the screws holes and ruining the shafts. Some grind off the ends of the screws so they can be more easily removed. You'll likely need new screws to replace them (use some red lock-tight).
There were some Q-Jet equipped cars that limited the opening of the air-valves but our Corvettes aren't one of them. Some 6-cylinder Panchos limited the AV opening.
2) The tension spring which controls the rate of the air-valve opening is more sophisticated than the writer believes. It's not that easily installed and a generic setting of 1/2 to 3/4 is good start but you'll need to adjust it for your engine's demands. An L-36 (q-jet equipped 427, 390hp) will want a quicker opening than an L-48.
2a) The writer believes ill-suited secondary rods is what leads to the infamous "quadra-bog". I disagree. An improperly set tension spring is usually the culpret. The bog usually occurs because the air-valves open too quickly.
3) The best place, in my opinion, to purchase q-jet parts is here:
http://www.carburetion.com/quadrajet.asp
...where rods are much less than $25 each.
4) I can't believe his secondary rod choices (DR, CP, and BA) for a performance car. All have a .0570 tip. Since a q-jet's secondary jets are static, the A/F ratio is solely controlled by the tip at WOT. The smaller the tip, the richer the mix. I run CE in colder weather (.0410 tip) or DA (.0443) in warmer weather. These selections are track tested on 69 Camaro with a healthy 406. Your engine may want a fraction richer or leaner rod than this, but it sure won't like anything with a .0570 tip; way to lean.
5) Lastly, I assume we'e talking about a street carb and if so, there are a few other things to consider for performance, like pump shot, and a larger needle and seat to compensate for the small fuel bowl.
FWIW
Man what knowledge this forum has, happy to have a Corvette(my younger dream) and joined this forum........So helpfull, thanks ED
FWIW
Thanks again ED
