I know there have been many thrds on this subject and, having read most of them, I'm having second thoughts on my current project.
My car is an '80, stock 350, 4-spd that was ovrhauled a few years ago with balanced crank, flat top pistons but no change in heads or cam. Don't know the CR but est. 9-9.5 to 1. The A.I.R. pump has been removed and true duals with headers added.
Performance still lacking, I decided to improve the top end but didn't have the budget for heads, intake, etc.
I'm now in the process of changing the stock .390 cam to a Lunati 60101, 213/219, .454/.468, but wanted to keep the other top end parts stock.
Recent threads, however, seem to indicate I may be in for a big disappointment. True??
If so, I may reach for the money to go with RHS vortec heads and performer intake and choose the 60102 cam.
Would appreciate some input before I put this torn-down engine back together.
Tks
that's all great but your build is incomplete, basicaly you have no flow...at minimal a cam should have been done on the rebuild but your on track with those vortec heads, if you want cheaper speak to a good machinist he may able to help on the stock heads...just keep in mind no machine shop can duplicate the 3 valve angle of a vortec head
I can't comment on the cam without knowing about your trans and diff ratio, but a .450 lift cam is in the ballpark. The flow on your existing heads tops out at about 180/125 @ .400 lift - so a cam change with those heads buys you exactly dick
You'll definitely need a head change to make significantly more power. You do NOT want to invest a single penny in those heads...and just having them overhauled is around $450+ which is in striking distance of a decent stock-replacement class iron head.
Vortec heads are a perfect budget choice, depending on your existing CR, but will require a new intake as well.
Tks
That cam 213/219, .454/.468 will make a significant difference over your L-48 cam 195 202 @.050 .390 .410. Go ahead & then you will be in a better position to know where you want to go from there- you may just want to add heads.
Thanks for the frank comments....it's pretty much what I expected.
As shown above, the transmission is the stock 4-spd and rear ratio is 3.08. SO....almost any cam upgrade goes begging due to the restrictive stock heads.
If I go for the RHS Vortecs there are two valve combos and three runner sizes. What's my best choice....and should I step up the cam size????
Thks, again
The more cam you give it the more head you need as a general rule...intake and air too, it's gotta work like a symphony so depending on what u want too much cam and not enough heads is a waste
With those freeway gears you'll want to boost your low end torque as much as possible. keep the intake runner small (180), this keeps air velocity up and enhances cylinder filling, and use small valves 1.94/1.50. the larger valves will only help above 5000 rpm
Yes, With the better flowing heads the 60102 would be a great choice. It will give you nice street manners and when you stick your foot in it will reward you with POWER.
Reason: cam comment
My mistake....the runners on those heads are 170cc. It's the combustion chamber that comes in three sizes, 64, 67, or 76cc??
Picking the 1.940/1.50 valves I'm guessing the choice would be 64 or 67cc. What's the deciding factor??
Duhhh...on checking Summit, the RHS 12407 heads with the 1.940/1.50 valves comes with 64cc comb chambers.
I chose the RHS over the GM Vortec based on flow tests shown in the Graham Hansen Car Tech book on HP Cyl Heads. However, those tests were with the larger valves. Anybody know the expected difference. Larger valves, lower velocity but highr pressure...any major perf difference??
Finally, I'm not a racer, so want higher torq at low rpm...good street performer.
Cheers..
Here is a nice set of low mileage heads at a fair price that would meet your needs with the bigger cam. I wouldn't worry about the 2.02 valves. The 4 speed will allow a little more cam and heads with those gears than an automatic. Hard to find a decent flowing performance head with the small valves. http://forums.corvetteforum.com/c3-p...70cc-67cc.html
Thks for the link. I sent him a PM to see if they are still avail.
From the flow data they don't look as good as the RHS Vortec but the perf/price looks much better...if they're in good cond.
I wouldn't get too wound up about maximizing flow with the power targets you're seeking; the GMPP Vortecs are likely your best budget purchase if you're going to invest in a new intake. This leaves you with no more than .475 lift so the cam choices narrow out a bit. With 3.08's, an "RV" or "4x4" cam will make more power down low by giving up a bit over 5K...but with a 4-speed if you like rowing the gears this doesn't matter quite as much.
As an aside, if you really want some "grunt" consider upgrading to 3.70 gears - this will make a huge difference seat of the pants.
Used heads are always a gamble to some extent - especially if they've had machine work done. Just IMHO.
Understand on the cam limits and agree, agree.
I have considered the gear change but maybe only to about 3.55 to keep the cruising rpm reasonable. Thks
Billa has some sound advice on the heads. The 256 cam is a great driver, Ive used it. Good idle and gobs of torque at a range youll use all the time.
Did an el cheapo build (which I dont like but his $) on an IROC. $895 10:1 shortblock, crappy Edelbrock heads, the 256 Voodoo, ported TPI and some shorties.
Suprisingly the car pulled like a mild stroker; in 2nd gear the car would push you back, hold you there and keep pulling;roasts the tires at will.
Thanks for all the input.
I found out my heads are casting #14022601, 267, 305 HO, 80-85, 58cc, 1.84-1.5, 7 bolt ex. The CA "smog" heads are #14014416 which has nearly equivalent specs. The stock '80 350ci head is #462624 which has 1.94/1.50 vlvs, 64cc.
billla is right, these heads are the main restriction and gotta go!!
I'm going to check out some reman shops. There are several pretty good looking sets of 2.02/1.60, 76cc reman heads available...half the price of new. Anyone have experience or know a reliable shop??
Thanks, again, for all the input.
You have 58CC heads now. Going to 76CC heads will drop compression about 2 full points. Look at the L98 corvette heads part #10088113. They will run pretty strong up to around 5500RPM, good bottom end and midrange torque. Have the 1.94 valves, 58CC and are aluminum. They are available inexpensively on Ebay. These are a good option also for under $1000 fully assembled with springs. http://www.summitracing.com/parts/TFS-30300001/
63mako...thks for the tip and link. I have looked on ebay and there are several possibilities. One is a set of #462624, 1.94/1.50, rebuilt w/springs for .510 lift and is the correct head for an '80 350 (ex CA). I think the (orig) comb cham is .622.
Wouldn't this work as well using the right gasket thickness to maintain a 9+:1 Cr??
Typo and question on the comb cham...the spec list "160/62cc ports" Does that mean 160cc runners and 62cc ports....or other?/
That is probably 160CC intake runners and 62cc exhaust ports. I would go with a smaller chamber than 64 if your running 58cc now and upgrading the cam. The trickflows I linked flow real well for a 1.94 head and the intake runner and exhaust port is more performance oriented. The stock 1980 heads suck. http://forums.corvetteforum.com/c3-p...all-block.html
