Tank sheet
Old Aug 10, 2009 | 05:15 PM
Drbluevert's Avatar
Drbluevert
Default Tank sheet
I know there is a build sheet somewhere around the gas tank, where exactly is it? Is there any way to see it or know one is there before tearing things apart?
Old Aug 10, 2009 | 05:54 PM
early shark's Avatar
early shark
Yes. It's sometimes visible by removing or lowering the rubber boot that surrounds the filler neck and sticking a small penlight flashlight and looking on top of the fuel tank. You can sometimes put your hand along the sides of gas tank and feel up on top from underneath the car and feel the piece of paper that is glued to the top of the tank.
Usually there is a film of dust on top of the tank from many years of use and is sometimes hard to see, dropping the exhaust and lowering one side of the tank is the best.
Old Aug 10, 2009 | 05:58 PM
69small block's Avatar
69small block
Default sheet
look around with a good light and mirror mine was on the drivers sidw of tank good luck you can use some felt paper for anti squeak pads when you put tank back in
Old Aug 10, 2009 | 11:22 PM
70454Convert's Avatar
70454Convert
You can see it thru the gas filler hole if you pull back the boot. If its there, just drop the tank.
Old Aug 11, 2009 | 09:13 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I found mine last year while I had the spare tire upper cover off to replace the leaf spring and it was dangling on the front side of the fuel tank , it's still there , Ron
Old Aug 11, 2009 | 12:10 PM
78Vette-SA's Avatar
78Vette-SA
This was where my 72 was. But I also found a pristine copy between the Tach and Speedo. I understand this was done occasionally but not sure if it was just 72 or if perhaps also in 71.
Unfoled and a little Dust-off:
Old Aug 11, 2009 | 12:16 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
I also found a perfect copy between the tach and the speedo (early build '71), stuffed up next to the dash. I've never actually looked to see if there was another on the tank!
Old Aug 11, 2009 | 02:56 PM
Mad Vette's Avatar
Mad Vette
Lucky bastards I have had my car completely apart and did not find it. It may have never been there or some one else found it.
Old Aug 11, 2009 | 03:37 PM
Alan 71's Avatar
Alan 71
I believe that sometimes the sheet was tucked behind the back of the radio. Since so many cars have had the radio changed those sheets are often gone. But still worth a look !
Regards,
Alan
To Tank sheet
