Need 4spd decoded
Old Aug 12, 2009 | 10:25 AM
bashcraft's Avatar
bashcraft
I may have missed it, but was the VIN found on the transmission?
Old Aug 12, 2009 | 01:14 PM
CCrane65's Avatar
CCrane65
Nope.
Old Aug 14, 2009 | 02:00 PM
gtplus2's Avatar
gtplus2
Okay, this is what I know so far... The trans is definatly a M-22, stamped housing numbers and letters bear this out. It is date coded Aug.28th 8/71, The production numbers on the car, and the d/s door it reads 9/71 along with matching production numbers. So the dates from the car to the trans work. There are NO other production numbers (from a different car) anywhere. This may prove that mistakes where made in My production numbers being absent. When the trans is pulled next week I will find out the number of splines. This set of conditions can only mean one of three things... One, this was a "special ordered car", two, the trans was a "fill in" to keep the line moving, the third it was used as a "warrenty replacement". This also explaines why this thing is SOOO LOUD (gear whine) in first and second gears!
Old Aug 14, 2009 | 05:09 PM
CCrane65's Avatar
CCrane65
Don't forget that in the date code on a transmission, the year is not the year the transmission was built but the model year of the car it's going into.
You car is 1972 model year car but the transmission is a 1971 model year transmission.
That August 28 date is for a 1970 build.
cc
Old Sep 1, 2009 | 09:08 PM
gtplus2's Avatar
gtplus2
Finally pictures of this trans, Is it a M22 or not?
Old Sep 2, 2009 | 12:54 AM
ROBRICCI's Avatar
ROBRICCI
cc
Not necessarily true in my experience...I have a (1973 stamped) M-20 transmission in my 1974 LS4 convertible. The car was built the 5th of November 1973 and is car #8167 of the assembly line (which is an early build) but not so early as to explain why I have a "3" stamped where a "4" should be on my "numbers matching" original transmission! See pic...
Old Sep 2, 2009 | 03:03 AM
Solid LT1's Avatar
Solid LT1
Originally Posted by Gordonm
My only problem with this is the 10 spline input shaft. I have an early build August car and it has a 26 spline input shaft. It is a 72. The car was built the second week of August so the trans should have been built before yours and it is a 26 spline. Mine has my VIN number on the side of the trans also. This may have been swapped into the car. If the trans is truely built in August of 71 it should be a 26 spline input, unless this is a freak car which could be possible.
10 spline input in a 72 Vette? NO WAY! EVER! all 71 up GM cars had 26 spline input shaft and TH400 large output shaft. Someone has swapped parts along the way.
Old Sep 2, 2009 | 09:42 AM
CCrane65's Avatar
CCrane65
My NCRS Technical Information Manual and Judging Guide only covers to 1972. You'll need to consult one covering 1973, 1974.
My answer still applies since the OP's car is a 1972.
cc
Old Sep 2, 2009 | 11:00 AM
Hammerhead Fred's Avatar
Hammerhead Fred
Based on your photos what you have is a M22 assembled for 1971 model year production (vette, chevelle, camaro).
Otherwise, your input/output shafts, main case casting number, output case casting number, side case casting number, assembly date stamping, and (would need closer photo but appears that) your drain plug being stamped with a "P" (all 70 & up had a drain plug but M22 is stamped P and is magnetic) are correct for a 1971 M22. Your casting date code on the main case appears to be missing or ground off.
The assembly model year and missing VIN is a killer for proving originality to your vehicle but at least you have a great gear box.
Note: only 20 M22's went into 1972 Corvette production for the ZR1.
Old Sep 2, 2009 | 12:53 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Here's a comparison shot for GTPLUS2 and other interested parties of another base motor, 4-sp, '72 car.
As you can see, mine is date coded P2P28A (the first "P" and "A" strikes are light, possible causes: fonts wearing, tool not flat on strike) and with the partial VIN immediately above the trans ID:
More close up:
If the ID stamping process was consistent (partial VIN & trans date code location and orientation), then the OP's trans is not following protocol. Not to say it didn't come in that car but methinks, his M-22 has been swapped in from another GM product of earlier vintage.
That's my story and I'm stickin' to it.
Old Sep 2, 2009 | 10:43 PM
gtplus2's Avatar
gtplus2
Wow! got it back today, the trans only needed an input shaft bearing and a few various o rings and gaskets. This M22 drives out sweet and smooth! As long as it was out I also opted for a new clutch pack as well. the numbers bear out that it was date stamped Aug. 28, 1971. The built tag on the D/S door say's 9/71, close enough for Me Guy's. This car is an original 94k car and has only had three owners (including me) I have been told that "mistakes" on the line have been found out about, and missing production numbers happened. I am impressed to hear that there where only "22" LT1's with the rockcrusher trans where ever made. My trans... and car... are dated in the same year and the same month... It's a match! Okay there are NO production numbers present, where they are suppost to be, perhaps this really make this a rare combination!
Old Sep 2, 2009 | 11:04 PM
Hammerhead Fred
You misunderstand the assembly stamp. That transmission was assembled Aug. 28 1970 for the 1971 production model run (see previous post by CCrane72). The final 1971 model Corvette was produced in July of 1971; they would not continue to stamp assembly codes for 1971 production in Aug of 1971 thus; your transmission was stamped and assembled Aug 28, 1970. That fact combined with the missing VIN means it's much more likely that the transmission was an "over the counter" replacement for the original.
Old Sep 3, 2009 | 08:12 AM
  #33
bashcraft's Avatar
bashcraft
Originally Posted by Hammerhead Fred
You misunderstand the assembly stamp. That transmission was assembled Aug. 28 1970 for the 1971 production model run (see previous post by CCrane72). That fact combined with the missing VIN means it's much more likely that the transmission was an "over the counter" replacement for the original.
How would you ever prove that the missing VIN was a "mistake".
My car is a '69 base 300 hp motor. When I bought it, it had a replacement (CE) '70 LT-1 engine, and the correct VIN derivitive is stamped on the original M-21 trans. Just sayin...
